[mapguide-users] New King.Oracle 0.6.1 Define FDO Class
Haris Kurtagic haris at sl-king.com
Thu Feb 15 10:40:33 EST 2007
I have just release a new version of King.Oracle provider v0.6.1.
New features are:
*	New KingFdoClass Table to define FDO classes
	*	Use of Oracle Views as FDO Classes
	*	Overriding FDO class Attributes like: Identity, Layer
Geometry Type, Name, Extent
	*	Create FDO Class from Tables/Views without geometry
column
	*	Creating FDO Class with points defined in columns with
numbers X,Y and/or Z
more Using KingFdoClass Table
<http://www.sl-king.com/fdooracle/KingFdoClass.htm>
*	Oracle NUMBER without scale defined is now cast to FDO DECIMAL
not INT
*	Insert Point trough provider - bug fixed
This is BETA release ( some attribute properties override in
KingFdoClass are not yet implemented and more testing is needed).
I would appreciate if you let me know how you use it and I am open to
suggestions specially about KingFdoClass.
There is also new version of Fdo2Fdo v0.6.1.
There is a button to create FdoClassTable in Oracle ( you need to enter
connection property KingFdoClass first).
You can use it also to check how King.Oracle provider is creating FDO
Classes.
www.sl-king.com/fdo2fdo
Haris
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070215/54d52d16/attachment-0001.html
