[mapguide-users] RE: RE: RE: RE: RE: ODBC Provider with SQL Server 2005: Doesit worksfor somebody?
pdtechguy patroam at gmail.com
Thu Feb 22 13:31:05 EST 2007
You Bet. Yea we are kinda lucky as far as the wireless goes.. several years
ago we had a mesh network built to cover the city. we typically have 512k to
the mobiles over apporox 90% of the city. Fire uses that in conjunction with
gprs as they travel outside the city limits occasionally.
The stream I get from cad is just an ascii stream containing cad unit data
and the raw gps string as output from the trimble(IE -
>RPV80974+4235984-1228854401428202<). By recomendations I mean recomending a
particular unit to respond to an incident based on gps data - not quite
there yet. We currently use Tiburon Unix CAD.
Pat
Brad Nesom wrote:
> Pat,
>  Thanks
> Wow wireless network! cool You mentioned a unix server is where the data
> goes to make it available. Is that an snmp stream or are you using
> something
> more like a gis format?
> I do remember your earlier post.
> By recommendations you mean to show how to catch the bad guys or similar?
> We use geolynx here for the mapping. No CAD but we are in the market. Do
> you
> know what 911 software your dispatch uses?
> Thanks for all the great info
> Brad
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of pdtechguy
> Sent: Wednesday, February 21, 2007 11:55 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] RE: RE: RE: RE: ODBC Provider with SQL Server
> Yes that was probably a bit confusing..I remember the days when cad meant
> design/drafting to me too. To answer you questions the gps data is
> captured
> by our mobile dispatch software(gps units are trimble placer and they are
> setup so they report every 50ft or 120 seconds whichever is first.) it is
> then routed over our wireless IP network to a unix server which makes the
> data available to our mapping software. from there I "steal"  it and feed
> it
> into two sql tables - one for historical data and one for last known
> location. the screen update is described in an earlier post.
> This is not our primary map. for that we use a product called maverick
> mapping. It has a mobile version as well as a dispatch version.  the
> latter
> is pretty tightly coupled with our cad system and shows all vehicle
> locations where the mobile shows only the units location it's installed
> in.
> we do not use gps for recomendations.
> My intent for Mapguide was/is a tool to replay AVL history for IA or
> incident critique. Right now I'm kinda taking a break from it as I had
> another project pop up that needed my attention. The next step for me is
> to
> learn how the JS/HTML part of it works.
> Pat
> Brad Nesom wrote:
>> Ok,
>>   the CAD is Computer aided dispatch. probably most of us thought you
>> meant
>> computer aided drafting. That's ok it's still interesting to me. I don't
>> really need to see it or the data. just descriptions of what you did to
>> make
>> the data flow work and are you displaying the points from sql serv? You
>> have
>> gps data streaming into your cad via ? you load it into standard db
>> tables
>> or sde? Then your screen update is done how?
>> BTW I would appreciate a contact offline. I am with a four county 911
>> agency.
>> bnesomatacogokdotorg
>> thanks
>> Well I'd love to show it to those interested but unfortunately the data
>> points are Police & Fire vehiclesâ?¦and Iâ??ve got a house payment to
>> make.
>> If
>> someone wants the Mapguide package Iâ??d be happy to put it on a ftp site
>> somewhere. The interface would probably be of little use unless you have
>> a
>> Tiburon cad system.
>> Brad Nesom wrote:
>>  > Very interesting. Can we hear more?
>>  > Sent: Tuesday, February 20, 2007 11:53 PM
>>  > Subject: [mapguide-users] RE: RE: ODBC Provider with SQL Server 2005:
>>  > Doesit
>>  > worksfor somebody?
>>  > What I did was really pretty simple... just not for me as I know very
>>  > little
>>  > about javascript or html(or maps for that matter)
>>  > 1.Created the basemap with streets and such(used our county data)
>>  > 2.wrote an interface to our cad system that parses out the gps data
>> and
>>  > unit
>>  > info and populates the sql table(s)
>>  > 3.Created a layer of points from that data (an odbc connection to a
>> sql
>>  > 2k5
>>  > server)
>>  > I had a lot of trouble with this part and would really like to hear
>> from
>>  > someone who's done it right -
>>  > 4. loaded this page as the taskpane (it's narrow enough you can's see
>>  > anything) it's just there for the code.
>>  > <html>
>>  > <head>
>>  >    <title>Test App</title>
>>  > </head>
>>  > <script language="javascript">
>>  > function reloadSpecificLayers(){
>>  > parent.parent.Refresh();
>>  > </script>
>>  > var initTimer = setInterval(reloadSpecificLayers, 10000);
>>  > </script>
>>  > </body>
>>  > </html>
>>  > IAs a whole it work great - much much better than I thought it would.
>> The
>>  > ajax client seems pretty intelligent and the refresh is imperceptible
>>  > except
>>  > that the points move.
>>  > Hope this helps.
>>  > Pat
>>  > ctallman wrote:
>>  >> pdtechguy,
>>  >> I would be interested in seeing what you have done and how.  I'm
>> working
>>  >> on an application similar to this.  Anything you are willing to share
>>  >> would be very helpful.
>>  >> Chris
>>  >> ________________________________
>>  >> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andrew
>>  >> DeMerchant
>>  >> Sent: Friday, February 16, 2007 8:03 AM
>>  >> To: MapGuide Users Mail List
>>  >> Subject: Re: [mapguide-users] RE: ODBC Provider with SQL Server 2005:
>>  >> Moving points, as in the locations move frequently? Do you have it
>> set
>>  >> up to refresh the points layer automatically?
>>  >> Andrew
>>  >> pdtechguy wrote:
>>  >> 	It works very good for an avl map that I created as a tech demo.
>>  >> It's is
>>  >> 	displaying 30'ish moving points on a street level tiled base map
>>  >> of our
>>  >> 	county. Be happy to share any info you'd like.
>>  >> 	BTW thanks to all who participate in this project.
>>  >> 	Here is the sql table that contains the points I am using:
>>  >> 	USE [AVL_CAD]
>>  >> 	GO
>>  >> 	/****** Object:  Table [dbo].[avl_last_known]    Script Date:
>>  >> 02/13/2007
>>  >> 	22:26:43 ******/
>>  >> 	SET ANSI_NULLS ON
>>  >> 	GO
>>  >> 	SET QUOTED_IDENTIFIER ON
>>  >> 	GO
>>  >> 	CREATE TABLE [dbo].[avl_last_known](
>>  >> 		[servertimestamp] [datetime] NULL,
>>  >> 		[cadunit1] [text] COLLATE SQL_Latin1_General_CP1_CI_AS
>>  >> NULL,
>>  >> 		[cadunit2] [text] COLLATE SQL_Latin1_General_CP1_CI_AS
>>  >> NULL,
>>  >> 		[caduser] [text] COLLATE SQL_Latin1_General_CP1_CI_AS
>>  >> NULL,
>>  >> 		[gpstimeofday] [text] COLLATE
>>  >> SQL_Latin1_General_CP1_CI_AS NULL,
>>  >> 		[lattitude] [float] NULL,
>>  >> 		[longitude] [float] NULL,
>>  >> 		[speed] [text] COLLATE SQL_Latin1_General_CP1_CI_AS
>>  >> NULL,
>>  >> 		[heading] [text] COLLATE SQL_Latin1_General_CP1_CI_AS
>>  >> NULL,
>>  >> 		[sourceofdata] [text] COLLATE
>>  >> 		[ageofdata] [text] COLLATE SQL_Latin1_General_CP1_CI_AS
>>  >> NULL
>>  >> 	) ON [PRIMARY] TEXTIMAGE_ON [PRIMARY]
>>  >> 	FGoulet wrote:
>>  >> 		Sure,
>>  >> 		Here's the script:
>>  >> 		USE [DredgingRegister]
>>  >> 		GO
>>  >> 		/****** Object:  Table [dbo].[Dredging_Activity]
>>  >> Script Date:
>>  >> 		01/31/2007 14:53:46 ******/
>>  >> 		SET ANSI_NULLS ON
>>  >> 		GO
>>  >> 		GO
>>  >> 		CREATE TABLE [dbo].[Dredging_Activity](
>>  >> 			[Activity_ID] [int] IDENTITY(1,1) NOT NULL,
>>  >> 			[UserName] [nvarchar](256) COLLATE
>>  >> 			[Location_FR] [nvarchar](32) COLLATE
>>  >> 			[Location_EN] [nvarchar](32) COLLATE
>>  >> 			[Description_FR] [nvarchar](32) COLLATE
>>  >> 		NULL,
>>  >> 			[Description_EN] [nvarchar](32) COLLATE
>>  >> 		NULL,
>>  >> 			[Start_Date] [datetime] NULL,
>>  >> 			[Finish_Date] [datetime] NULL,
>>  >> 			[Dredging_Type_CD] [int] NULL,
>>  >> 			[Material_Quantity] [numeric](9, 3) NULL,
>>  >> 			[Material_Disposal] [nchar](10) COLLATE
>>  >> 		NULL,
>>  >> 			[Longitude] [float] NULL,
>>  >> 			[Latitude] [float] NULL,
>>  >> 			[Registration_Date] [datetime] NULL,
>>  >> 			[Approved] [bit] NULL,
>>  >> 			[Proponent_ID] [int] NULL,
>>  >> 			[Responsible_ID] [int] NULL,
>>  >> 		 CONSTRAINT [PK_Dredging_Activity] PRIMARY KEY CLUSTERED
>>  >> 			[Activity_ID] ASC
>>  >> 		)WITH (PAD_INDEX  = OFF, IGNORE_DUP_KEY = OFF) ON
>>  >> [PRIMARY]
>>  >> 		) ON [PRIMARY]
>>  >> 		GO
>>  >> 		ALTER TABLE [dbo].[Dredging_Activity]  WITH CHECK ADD
>>  >> CONSTRAINT
>>  >> 		[FK_Dredging_Activity_Contact] FOREIGN
>>  >> KEY([Responsible_ID])
>>  >> 		REFERENCES [dbo].[Contact] ([Contact_ID])
>>  >> 		GO
>>  >> 		ALTER TABLE [dbo].[Dredging_Activity] CHECK CONSTRAINT
>>  >> 		GO
>>  >> CONSTRAINT
>>  >> 		[FK_Dredging_Activity_Dredging_Type] FOREIGN
>>  >> KEY([Dredging_Type_CD])
>>  >> 		REFERENCES [dbo].[Dredging_Type] ([Dredging_Type_CD])
>>  >> 		GO
>>  >> 		GO
>>  >> CONSTRAINT
>>  >> 		[FK_Dredging_Activity_Proponent] FOREIGN
>>  >> KEY([Proponent_ID])
>>  >> 		REFERENCES [dbo].[Proponent] ([Proponent_ID])
>>  >> 		GO
>>  >> 		The columns mapped to X and Y in MG Studio are Longitude
>>  >> and Latitude. I
>>  >> 		tried with  others numeric type (real, decimal, numeric)
>>  >> and I always get
>>  >> 		that error.
>>  >> 		Thanks
>>  >> 		JasonBirch wrote:
>>  >> 			Frederic wrote:
>>  >> 			        An exception occurred in FDO component.
>>  >> 			        RDBMS: Incompatible column type
>>  >> 			Care to share the table definition?  The problem
>>  >> with ODBC is that it's
>>  >> 			not generic enough :)
>>  >> 			Jason
>>  >> 			_______________________________________________
>>  >> 			mapguide-users mailing list
>>  >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>  >> Andrew DeMerchant
>>  >> Computer Technologist
>>  >> ph.1-877-2GEMTEC x.163
>>  >> fax 506-453-9470
>>  >> GEMTEC Limited <http://www.gemtec.ca>
>>  >> 191 Doak Road
>>  >> Fredericton, NB, Canada
>>  >> E3C 2E6
>>  > View this message in context:
> http://www.nabble.com/ODBC-Provider-with-SQL-Server-2005%3A-Does-it-works-fo
>>  > r-somebody--tf3144880s16610.html#a9075760
>>  > Sent from the MapGuide Users mailing list archive at Nabble.com.
> r-somebody--tf3144880s16610.html#a9093035
>> _________________________________________________________________
>> Mortgage rates as low as 4.625% - Refinance $150,000 loan for $579 a
>> month.
>> Intro*Terms  http://www.NexTag.com
> r-somebody--tf3144880s16610.html#a9094851
View this message in context: http://www.nabble.com/ODBC-Provider-with-SQL-Server-2005%3A-Does-it-works-for-somebody--tf3144880s16610.html#a9105579
