[mapguide-users] Properties pane not displaying correct attributes.
Andy Morsell amorsell at spatialgis.com
Tue Feb 27 11:20:14 EST 2007
You are probably have the problem described in this recent thread.  I also
had the same issue and applying the fix worked.
http://www.nabble.com/RE%3A--Mapguide_users--Courious-behavior-of-Properties
-pane-withSetSelection-tf2942020s16610.html#a8226351
Andy
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Nico Alberti
Sent: Tuesday, February 27, 2007 7:44 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Properties pane not displaying correct attributes.
Hello all
I am doing some tests on a layer representing a channel grid, generating a
selection in the Task pane, and then passing that selection to the Map frame
and zooming the Map frame to the selection.
The selection works correctly, since the channel I am selecting turns blue,
and the map zooms accordingly. Sometimes, however the property pane is
populated by the data of a connected channel, not the one I selected.
Doing some search in the list I found cases where the property pane was not
populated, but I did not find any previous case of this behaviour.
I am quite a newbie, and in my tests I am tweaking the mapviewerphp example,
perhaps I did forget something, but, as far as I know I did not touch the
code regarding the property display.
Any help would be greatly appreciated. Thank you in advance and sorry for my
poor English.
Ciao
Nico
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
