[mapguide-users] Request for help inserting new row into SDF file.
Matthew D matthew.dunstan at nanaimo.ca
Tue Feb 27 14:16:31 EST 2007
I am attempting to insert a feature/record into an SDF file.  The record does
not have any geometry.
I have no problem returning data from this code
$featureReader = $featureService->SelectFeatures($featureResId, $class,
$queryOptions);
The insert method doesn't seem to work AND does not give any error messages
why not.
$propertyValues = new MgPropertyCollection();
$propertyValues->Add(new MgInt64Property('mow_id', 3));
$propertyValues->Add(new MgInt64Property('seg_id', 2231));
$propertyValues->Add(new MgInt16Property('percent_required', 100));
$propertyValues->Add(new MgStringProperty('contractor', 'Mow Machine 65'));
$propertyValues->Add(new MgStringProperty('mow_date', '20070202'));
$propertyValues->Add(new MgStringProperty('comments', 'Some comments'));
$commands = new MgFeatureCommandCollection();
$commands->Add(new MgInsertFeatures($class, $propertyValues));
$featureService->UpdateFeatures($featureResId, $commands, false);
Could someone tell me if there is something I am missing, or if there is
some way to find out why this is not working?
Thanks,
Matt
View this message in context: http://www.nabble.com/Request-for-help-inserting-new-row-into-SDF-file.-tf3303740s16610.html#a9189669
