[mapguide-users] Studio and moving folders...
Kori Maleski Kori.Maleski at websoftdev.com
Tue Jan 16 16:31:59 EST 2007
It would also be nice to be able to:
1 - Copy a layer that has themes and save it as a new layer.
2 - Load a new Feature Source that has identical file/db structure.
3 - re-assign the new layer copy's feature source to the new feature source
and preserve all themes.
Circumstances it would apply:
Creating a very complex themed layer on a file containing a subset of data;
and wanting to create an identically themed layer on a full set of data
without having to painstakingly recreate all themes.
Essentially you are creating a new layer and swapping the datasource.
This was something you could do in 6.5 and cut off hours of cartographic
prep.
A save/load themes function in Studio would be a dream.
A save/load colour palette would be an additional bonus.
Cheers,
Kori Maleski
Senior Application Developer
WEBSOFT DEVELOPERS, INC.
P: (530) 759-8754 ext 114
F: (530) 759-0923
kori.maleski at websoftdev.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Willem Schwarte
Sent: Tuesday, January 16, 2007 4:35 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Studio and moving folders...
It would be nice if you could move a folder to another subfolder and be
able to keep theming rules.
If I try to move a folder, now the reference is broken, and if I
re-attach the correct feature resource, all theming is lost.
When I move the folder back to the original position in the tree, then
the theming is back to how it was.
So I'm assuming that somewhere there is a file that describes the
theming for a layer at a specific position in the tree, or of a specific
resource at a specific location. So if you moved a folder, this file
should be updated to the new position.
Or is it already possible to keep theming rules while moving layers?
Willem
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
