[mapguide-users] web studio - feature data setup?
TW twiebe at cityofwinkler.ca
Mon Jan 29 09:34:10 EST 2007
Zak,
Yes, the sdf file and shp files are in the library respository folder on the
server.
However web studio will not allow me to create an unmanaged feature source.
Any suggestions? Is there more setting up to do with IIS?
Zak James wrote:
> Tim,
> Can you search through the repository to see if the sdf file is
> actually present on the server? I'm wondering if there is some IIS
> specific issue with the upload mechanism. It works under apache.
> Another thing you could try is creating an unmanaged feature source
> (pointing it to a file/folder already on the server) to see if that
> allows you to create a layer.
> zak
> On 1/26/07, TW <twiebe at cityofwinkler.ca> wrote:
>> When I try to create a layer from an uploaded data source in web studio
>> it
>> will not allow me to occupy the feature class or geometry fields to setup
>> the layer.
>> Web studio will allow me to create a feature data source and upload
>> either a
>> shp file or sdf, and yes it does actual create a folder in the
>> respoistory
>> and makes it available.
>> I am running the server on IIS 5. Am I missing something obvious? I have
>> used the enterprise software and it works fine. But I cannot use the
>> Opensource.
>> What am I missing?
>> Tim
>> View this message in context:
>> http://www.nabble.com/web-studio---feature-data-setup--tf3124673s16610.html#a8657214
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zak James
> Applications and Software Development
> DM Solutions Group Inc.
> http://www.dmsolutions.ca
View this message in context: http://www.nabble.com/web-studio---feature-data-setup--tf3124673s16610.html#a8690301
