[mapguide-users] Example configuration for mapguide on apache/linux?
matt underwood sakkaku at gmail.com
Tue Jul 3 10:10:41 EDT 2007
I am a little concerned with keeping apache up to date.  The current version
is 2.2.x while the apt installer has 2.0.x iirc.
Redoing the OS really isn't an option ATM.  Can anyone provide the samples
or provide info on where they reside within the apt installer package?
On 7/3/07, Chris Gountanis <cgountanis at mpower-tech.com> wrote:
> If you want to see everything in working order. Setup a test box with
> CentOS
> 4.5 (redhat Ent). Everything works great as far as server/web and base
> FDO.
> That is the supported OS as far as I have heard from Autodesk and
> everything
> works great. I spent many weekends debugging when it could not have been
> easier :)
> CentOS 4.5 install with full development / workstation and go nuts with
> the
> MG install documentation.
> Chris
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of sakkaku
> Sent: Tuesday, July 03, 2007 8:43 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Example configuration for mapguide on
> apache/linux?
> I was wondering if anyone has the base configuration files provided by the
> "apt installer" in linux.  I would much rather use an existing apache
> installation and the apt package does not compile cleanly on this machine
> without downgrading curl (due to old functions removed yet still used by
> apache 2.x provided with the tarball).
> I would suggest the installation page for linux also list steps for not
> using the apt package.  I would gladly help write these documents based on
> an installation within fedora core.
> So far I have gotten all the virtual directories linked up and the sites
> work great.  Except for the mapagent.fcgi which gives a permission denied
> with the various ways I have tried to alias it (to mapagent/mapagent).
> Thank you all for your time,
> Matt.
> http://www.nabble.com/Example-configuration-for-mapguide-on
> -apache-linux--tf
> 4018343s16610.html#a11412404
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070703/a659e30e/attachment.html
