[mapguide-users] RE: Coords files on 64 bit machine
Jim O'Leary joleary.public at gmail.com
Tue Jul 10 12:28:42 EDT 2007
Yes, MapGuide on 64 bit installs to
C:\Program Files (x86)\
The coords files thus install to
C:\Program Files (x86)\Common Files\Autodesk Shared\Gis\CoordSys\11g
This is the correct path setting in the registry key. There are no other
coords files on the machine, so Studio is definitely reading those
dictionary files. It is just not picking up the BC Albers definition when I
replace those coords files.
Andy Morsell wrote:
> I've only worked with MGOS on an 64 bit machine, but in that case, all 32
> bit programs are installed under the Program Files (x86) folder rather
> than
> Program Files.  Are you sure that isn't where you should be copying the
> files to instead?
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jim O'Leary
> Sent: Tuesday, July 10, 2007 8:45 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Coords files on 64 bit machine
> We need the BC Albers coordinate system in our MapGuide dictionary. With
> the
> current MGE I am able to change the coordsys.CSD and category.CSD files as
> this posting suggests:
> http://discussion.autodesk.com/thread.jspa?threadID=514332
> .by copying them to the
> C:\Program Files\Common Files\Autodesk Shared\Gis\CoordSys\11e
> folder. At that point, BC Albers shows up in Studio under Canada
> Provinces.
> However, this does not work with MGE 2008, possibly because we have a 64
> bit
> machine. Looking at the registry settings, I can see that the
> HKEY_LOCAL_MACHINE -> SOFTWARE -> Wow6432Node -> Autodesk -> GIS ->Coorsys
> ->11g keys map correctly to the Category.CSD and Coordsys.CSD files.
> However, BC Albers does not show up in Studio.
> Has anyone had this experience on a 64 bit machine? Any solutions?
> Thanks
> http://www.nabble.com/Coords-files-on-64-bit-machine-tf4056645s16610.html#a1
> 1523589
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/Coords-files-on-64-bit-machine-tf4056645s16610.html#a11524382
