[mapguide-users] MapAgent.exe persists after browser close
nicholda nicholda at talgov.com
Tue Jul 17 08:47:24 EDT 2007
Thanks for your response Kenneth,
Our issue seems to be that the functionality we are trying to provide winds
up creating additional MapAgent.exe processes as a result of a successful
run.  Essentially we are opening the map, creating serveral new layers with
1 to many points on each one, pushing the layers into the map, then storing
the map back in the repository with the users sesssion.
The report looks great.  However, when the map refreshes, it creates a new
MapAgent.exe process.  So, if we create 40 reports, we reach max class
processes reached and then have to manually go in and start killing
processes / restarting MapGuide.
The code we are using was taken / modified from the development guide; I can
tell you that we are not doing anything explicity to close any of the
resource or feature services created; is there a chance that a simple
featureService.close() or something related could keep this from happening?
Or does the creation of new layers on the fly necessitate the creation of a
new MapAgent.exe process and our only option includes kicking the timeout
down from 120 seconds.
Any and all insight is appreciated.
Thanks,
David
Kenneth, GEOGRAF A/S wrote:
> I belive that MapAgent.exe is supposed to keep running.
> IIS/Apache will load/unload fastCGI, to avoid continously reloading
> MapAgent.exe.
> If you are using WinXP IIS, you are likely refering to the IIS
> connection limit on WinXP.
> You can increase the number of allowed connections to 40.
> Instructions can be found here:
> http://weblogs.asp.net/cazzu/archive/2003/10/10/31476.aspx
> Regards, Kenneth, GEOGRAF A/S
> nicholda skrev:
>> Hi All,
>>   I am having trouble with MapAgent.exe, after closing the web browser
>> MapAgent.exe is still running in the background.  Eventually I hit the
>> max
>> number of connections and can't make another connection until I manually
>> end
>> the MapAgent processes running in the background.  I am running MGOS 1.2.
>> Could someone point me in the right direction for resolving this issue.
>> Thanks,
>> David
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/MapAgent.exe-persists-after-browser-close-tf4090604s16610.html#a11648611
