[mapguide-users] Any coord. system to WGS84 (Google Earth)
Jose Manuel C G gis at mapas-sll.com
Fri Jul 20 07:48:18 EDT 2007
Thk, I'm trying to implement, but is difficult with my knowledge.
Kenneth, GEOGRAF A/S wrote:
> I've found this code i buffer.php:
> $srsFactory = new MgCoordinateSystemFactory();
> $srsDefMap = GetMapSRS($map);
> $srsMap = $srsFactory->Create($srsDefMap);
> $srsXform = new MgCoordinateSystemTransform($srsDs, $srsMap);
> $geomBuffer = $geom->Buffer($dist, $measure);
> $geomBuffer = $geomBuffer->Transform($srsXform);
> I have not tested it, but it should work. See the file buffer.php in the
> mapviewerphp folder.
> Regards, Kenneth, GEOGRAF A/S
> Jose Manuel C G skrev:
>> I have my map in Ed50 UTM 29N system, and I want to make a parser to
>> dinamically create a .kml file in WGS84, but I don't know how to do that
>> (the transformation, the parser works).
>> Can I use PROJ_4 to change this proyection in the .php file?
>> Thks a lot.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Any-coord.-system-to-WGS84-%28Google-Earth%29-tf4085738s16610.html#a11706731
