[mapguide-users] Opening a URL from a layer
James Card James.Card at calcad.com
Fri Jul 20 20:41:12 EDT 2007
On Fri, 20 Jul 2007 05:18:25 -0700, jamesdudden
<jamesdudden at blueyonder.co.uk> wrote:
> Is there a way to click on the individual line to open Access and make
> the whole record available? The thought then being to use a script in
> Access to go straight to that record.
What you probably should do is join that Access table to your MapGuide
feature source and just let the MapGuide interface display the records
 from the Access table directly. It would be very messy and difficult to
try to script a link directly back to the .MDB file, and would only work
for someone who has Access installed on their local machine.
In the MapGuide Studio help files look at these sections:
"Connecting to an ODBC Database"
"Using Feature Joins"
"Specifying the Properties to Display in the Viewer"
James Card
209-578-5580
