[mapguide-users] Vista and Mapguide Server
Ivan Milicevic ivan.milicevic at supranet.hr
Mon Jul 30 09:55:09 EDT 2007
Is it possible to hve IIS and Apache on Vista? I can not afford removing
IIS because of many other web application.
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Martin
Morrison
Sent: Monday, July 30, 2007 3:53 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Vista and Mapguide Server
User Account Control is wonderful for most users, however for most
people doing development/support work it simply gets in the way.  I had
already turned mine off long before I got around to loading Mapguide.
Martin
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Angela
Moore
Sent: Monday, July 30, 2007 9:04 AM
Subject: Re: [mapguide-users] Vista and Mapguide Server
I've got MapGuide Server (1.2 RC2) running on Vista (32 bit).  I used
the self extracting executable for windows and installed with
Apache/PHP.  I ran into and fixed one  glitch while installing the
samples to test the program on Vista.  Because MapGuide is installed in
Program Files the all too annoying user permissions start to kick and
scream in protest.  I had to allow all permissions for my administrative
account within Program Files and then run the zip program in the Windows
XP mode to open the sample files before I could get them installed.
Eventually I just had to turn all of the User Account Controls off so
that I could properly load data.  I know that Vista is trying to be
/secure/ but their User Account Controls just give me headaches on a
regular basis.  I would suggest that anyone having trouble with a Vista
installation regardless of which web server or programing language you
are using try turning off User Account Controls and giving it another
swing.  Good luck!
Angela Moore
GIS Analyst
Town of Franklin, NC
amoore at franklinnc.com
Ivan Milicevic wrote:
> What's the key of sucesfully instalation? Share with us :)
> From: mapguide-users-bounces at lists.osgeo.org
> Morrison
> Sent: Friday, July 27, 2007 1:19 PM
> I do.  64bit too.  Mapguide Studio will NOT work with the 64 bit
though.
> Martin
> From: mapguide-users-bounces at lists.osgeo.org on behalf of Kenneth,
> GEOGRAF A/S
> Sent: Fri 7/27/2007 6:49 AM
> You don't have to use the same machine.
> In the webconfig.ini, you can specify IP and port mappings for the
> server.
> Does anyone have a working MapGuide Server on Vista?
> Regards, Kenneth, GEOGRAF A/S
> Ivan Milicevic skrev:
>> I need mapguide server on same machine where is my source code of
> application because of developing.
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Bruno
>> Scott
>> Sent: Friday, July 27, 2007 12:21 PM
>> To: mapguide-users at lists.osgeo.org
>> I have just installed Mapguide Studio 2008 on my bran new Vista
>> Ultimate And it works fine.
>> Didn't try to install Mapguide Server
>> I have a vmware virtual machine that runs windows 2003 with mapguide
>> server on it.
>> With this configuration, i got everything running, it's even faster
>> having mapguide server on a virtual machine than on the same machine.
>> Don't know why?
>> Bruno Scott
>> Ivan Milicevic-3 wrote:
>>> Hello,
>>> Just for information, Vista doesn't support Mapguide Server (any  of
>>> version). It's problem with IIS 7.0.
>>> Also, Mapguide Studio 2008 (2007 work's perfectly) doen't work on
>>> this platform.
>>> I hope so that this compatibility issue will be solved in futer
>>> version od Mapguide Server and Studio.
>>> Ivan Milicevic
>>> voditelj Odjela za dokumentiranje
>>> i projektiranje
>>> SUPRA NET d.o.o.
>>> Erlichova 2, 10000 Zagreb
>>> CROATIA
>>> Mobile: +385 (0)91 2352-320
>>> Fax: +385 (0)1 6678-728
>>> Email: ivan.milicevic at supranet.hr
<mailto:ivan.milicevic at supranet.hr>
>>> URL: www.supranet.hr <http://www.supranet.hr/>
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
