[mapguide-users] Data connection to raster...
Ben_D majabak at hotmail.com
Mon Jul 30 11:27:10 EDT 2007
I'm trying to get MrSID rasters to show in MapGuide. I've had them working
without a problem, but keep getting the same error when I attempt to make a
data connection on a new set up. I'm working in VMware running Windows 2003
Server and Apache. Both setup's are identical (ie - two copies of the same
virtual machine) and I am using the patched trial version of Autodesk
MapGuide Studio.
I have triple checked the install process for MrSID support (The
MapGuide1.1.0_GDAL patch and the two patches from
http://home.gdal.org/dl/mapguide/ (mg_fdogdal_110 and mg_mrsid_110) and
followed the same process on both setups.
The only difference is that when I use the "Test Connection" on the computer
that won't show the MrSIDs I get the following error:
Resource was not found:
Session:5c15fb9e-0000-1000-8000-000c29375b51_en//FeatureSourceEditorsScratch/SessionVersion6.FeatureSource
Obviously the session number changes each time. Whats weird is that when I
set up a data connection and test it, I dont get the error message. But as
soon as I make a layer, the error message appears and nothing shows in the
web layout. The resource is is sitting in the right location (C:\Documents
and Settings\Administrator\Desktop\Projected\c01c.sid) and works on an
identical set up.
I'm pulling my hair out trying to solve this so any help would be
appreciated!
Thanks!
View this message in context: http://www.nabble.com/Data-connection-to-raster...-tf4170902s16610.html#a11865791
