[mapguide-users] MapInfo problem
Jackie Ng jackie.ng at aecsystems.com.au
Tue Jul 31 01:17:17 EDT 2007
Hi Stefan,
It sounds like the "mapviewerajax" virtual directory has not been setup /
registered as an application.
Are you using Apache or IIS?
Does a url like this work for you?
http://localhost/mapguide/mapviewerajax/?WEBLAYOUT=<Path to a weblayout
resource>
OR
http://localhost:8008/mapguide/mapviewerajax/?WEBLAYOUT=<Path to a weblayout
resource>
- Jackie
Stefan Dalakov wrote:
> I have to apologize, It is not connected to the provider. There is
> something wrong with viewer. When I set the MG Studio to work with dwf
> viewer
>  it is OK. With the AJAX viewer I get this problem. I had Studio 2008
> recently installed, so I guess there is the problem. Help will be
> appreciated anyway....
>> Hi all,
>> I try to open Mapinfo files (TAB,DAT...) - rather old ones - version
>> 3. I have installed the OGR provider. Test connection succeeds and in
>> the preview pane of MG Studio I see data and geometry description.
>> When I click on "View data" I see attributes listed - works perfect,
>> but when I click on "view feature" and I expect to see features, I get
>> this message :
>>   Directory Listing Denied
>> This Virtual Directory does not allow contents to be listed.
>> What's wrong ? I am using MGOS 1.2RC2 on WinXP, I have no problem with
>> other data sources
>> Thank you in advance : Stefan Dalakov
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/MapInfo-problem-tf4169277s16610.html#a11918328
