[mapguide-users] Problem with legend - style
James Card James.Card at calcad.com
Fri Jun 1 11:40:48 EDT 2007
On Fri, 01 Jun 2007 06:48:01 -0700, martijni <mis at gemeentehulst.nl> wrote:
> I understand what you say, but do I have to reload the XML using the
> mapagent interface like this way:
> Resource --> SetResource --> Resource ID is location where the file will
> be placed
> Content is the location of the xml file
> Header is empty
> But when I did it this way I received an exception. Is this the way you
> should do it, or did you mean something else?
That is exactly the procedure we use here. Did you mistype the Resource
ID? Is your XML file valid?
James Card
California CAD Solutions, Inc.
209 578-5580
