[mapguide-users] SHP Files Strike Again
Dave Wilson dave.wilson at autodesk.com
Mon Jun 4 14:56:52 EDT 2007
Chris are you still trying to connect to a folder for SHP? It may be
that that is part of the issue. It might be worth falling back to a
resource per SHP file just like you have to do with SDF.
Regards,
Dave
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris
Gountanis
Sent: Monday, June 04, 2007 12:14 PM
To: 'MapGuide Users Mail List'
Subject: [mapguide-users] SHP Files Strike Again
I was playing around with my unmanaged SHP files and now the server just
crashes on zoom. I created a separate unmanaged feature source to see
if it was faster zoom wise and that seemed to cause the issue. I also
edited the layer to use new feature source with single SHP file and the
preview in Studio works fine. When bring the whole site up with AJAX
viewer the issue shows its face. Is there a reason why or a way to clear
cache? I had turned on SHP cache for pooling tests maybe that caused an
issue? I am not sure what the server is doing but it using 100%
resources then crashes on zooms now.
Chris
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070604/be2cf4e6/attachment.html
