[mapguide-users] Optimal Settings for Feature Service in ServerConfig.ini ? ? ?
Chris Gountanis cgountanis at mpower-tech.com
Tue Jun 5 14:59:53 EDT 2007
Can someone who has inside knowledge explain the optimal settings for
pooling and feature sources? Say you have 2 GB of memory or would it be
easier to explain 1GB and just have people 2x per GB after?
[FeatureServiceProperties]
# F E A T U R E  S E R V I C E
# Property Name                    Description
# DataCacheSize                    Max # of features to fetch
#                                       0 < Value <= 2147483647
# DataConnectionPoolSize           # of connections to cache
#                                       0 < Value <= 1024
# DataConnectionTimeout            Time duration in seconds for when an idle
#                                  connection is dropped
#                                       0 < Value <= 86400
# DataConnectionTimerInterval      Time interval in seconds for when the
server
#                                  checks for idle connections
DataConnectionPoolExcludedProviders = OSGeo.SDF
DataConnectionPoolEnabled = 1
CacheTimerInterval = 3600
CacheTimeLimit = 86400
CacheSize = 1000
DataConnectionTimerInterval = 60
DataConnectionTimeout = 600
DataConnectionPoolSize = 200
DataCacheSize = 1000
Chris
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070605/4273fe75/attachment.html
