[mapguide-users] About tooltip on marker
Jackie Ng jackie.ng at aecsystems.com.au
Fri Jun 8 02:07:36 EDT 2007
I think what you have to do is modify the underlying LayerDefinition xml of
that push pin layer to incorporate your caption. (You want to seek out the
<ToolTip></ToolTip> portion of the xml, insert your caption there, and save
the modified xml)
- Jackie
akj006 wrote:
> Hi Everybody,
> I have added push pin on the map. Along with this push pin, I need to
> display caption. Please help me in this regard...
> Thanks...
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/About-tooltip-on-marker-tf3884633s16610.html#a11021015
