[mapguide-users] OGR and MGOS
martijni mis at gemeentehulst.nl
Fri Jun 8 08:01:52 EDT 2007
Kenneth,
Thanks for your help (once again you helped this noob ;) )
I earlier tried to just use the map instead of pointing to the file, but it
had same result. Though what I didn't knew was that it fails when there are
"bad" files in the folder. So it can only makes connection when there are:
DAT, ID, IND, MAP, TAB and DBF files are in the folder...
It couldn't connect to the MI folder, but when I copied those extensions to
an other map it made a connection....
So it seems that I have to let the files get updated by a script instead of
making a direct connection.
Kenneth, GEOGRAF A/S wrote:
> You must point to the folder, not the tab file.
> You can then choose all the tab files as schemas.
> Beware that it will break if there are "bad" (non MI) files in the folder.
> Regards Kenneth, GEOGRAF A/S
> martijni wrote:
>> Kenneth,
>> I downloaded your OGR, because the 3.2.1 and 3.2.2 version ain't working
>> (3.2.2 beta is understandable since it's for MGOS 1.2, but 3.2.1 should
>> be
>> working, but shows no datasource and read only).
>> After I tried yours it's shows the datasource and readonly, but when I
>> try
>> to make a connection it seems not possible as you can see on the
>> screenshot....
>> http://www.nabble.com/file/p11023030/ogr.jpg
>> These is what I've added in the providers.xml
>>         <FeatureProvider>
>>             <Name>OSGeo.OGR.3.2</Name>
>>             <DisplayName>FDO Provider for OGR</DisplayName>
>>             <Description>Access to OGR data sources</Description>
>>             <IsManaged>False</IsManaged>
>>             <Version>3.2.2.0</Version>
>> <FeatureDataObjectsVersion>3.2.0.0</FeatureDataObjectsVersion>
>> <LibraryPath>C:\ProgramFiles\MapGuideOpenSource\Server\Bin\FDO\OGRProvider.dll</LibraryPath>
>>        </FeatureProvider>
>> My intention is to get connection with mapinfo files.
>> Any idea's in what I'm doing wrong?
>> Thanks in advance.
>>> I have built and posted providers for FDO 3.2 (MgOS 1.1) and FDO 3.1
>>> (MgOS 1.0 and MgEP 1.0 + SP1).
>>> The providers are built without Oracle support, using the latest OGR
>>> provider code from Traian.
>>> The manifest has been removed from these, hopefully fixing a few
>>> problems.
>>> Download and use, is on your own risk. I provide no support for them.
>>> http://www.hexad.dk/MapGuide/OGR Provider Release FDO 3.2 - Proj 4.5.0 -
>>> GDal 1.3.2 - Geos 2.2.3 - No OCI.zip
>>> http://www.hexad.dk/MapGuide/OGR Provider Release FDO 3.1 - Proj 4.5.0 -
>>> Regards, Kenneth, GEOGRAF A/S
>>> Traian Stanev wrote:
>>>> The 3.2.2 build will not work with MapGuide 1.1, it is compiled for
>>>> MapGuide 1.2. You need to try an older build of the DLL (3.2 perhaps?)
>>>> or wait for MapGuide 1.2.
>>>> There is another problem that may cause connection properties to not
>>>> show up, which someone on this list traced to manifest issues in the
>>>> dll. I hope to have a build of the dll without manifest (and with the
>>>> fix for S57 files) posted some time soon. It will be a 3.2.2 build.
>>>> In any case, I believe you have the first problem -- your OGR provider
>>>> build is too new.
>>>> Traian
>>>>     -----Original Message-----
>>>>     *From:* mapguide-users-bounces at lists.osgeo.org on behalf of Rahul
>>>>     *Sent:* Tue 5/15/2007 6:52 AM
>>>>     *To:* MapGuide Users Mail List
>>>>     *Cc:*
>>>>     *Subject:* RE: [mapguide-users] OGR and MGOS
>>>>     Hi,
>>>>              I tried to configure  OGR Provider 3.2.2_beta1 with
>>>>     MapGuide Open Source 1.1.0 ,Finally when i tried to connect the
>>>>     database using the OGR Provider(Using Map Guide Studio) I unable
>>>>     to get the Connection Properties in the Editior,Like DataSource &
>>>>     ReadOnly etc .Kindly refer to the screen shots.
>>>>     Thks
>>>>     Max
>>>>     */Chris Gountanis <cgountanis at mpower-tech.com>/* wrote:
>>>>         Using this download:
>>>> http://download.osgeo.org/fdo/3.2.2-Beta1/OGRProvider-3.2.2_beta1.win32.zip
>>>>         Put the OGRProvider.dll in C:\Program
>>>>         Edited the C:\Program
>>>>         Files\MapGuideOpenSource\Server\Bin\FDO\providers.xml
>>>>         Added:
>>>>           <FeatureProvider>
>>>>             <Name>OSGeo.OGRProvider.3.2</Name>
>>>>             <DisplayName>OSGeo FDO Provider for ArcSDE </DisplayName>
>>>>             <Description>Read/write access to an ESRI ArcSDE-based
>>>>         data store, using Oracle and SQL Server. </Description>
>>>>             <Version>3.2.2_beta1</Version>
>>>> <FeatureDataObjectsVersion>3.2.1.0</FeatureDataObjectsVersion>
>>>>             <LibraryPath>OGRProvider.dll</LibraryPath>
>>>>           </FeatureProvider>
>>>>         I copied the FeatureProvider from above "ArcSDE". Once I
>>>>         updated the DisplayName and Description to something like
>>>>         <DisplayName>OSGeo FDO Provider for OGR </DisplayName> it
>>>>         worked great J
>>>>         Chris
>>>>         ________________________________________
>>>>         From: mapguide-users-bounces at lists.osgeo.org
>>>>         [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of
>>>>         Traian Stanev
>>>>         Sent: Friday, May 11, 2007 1:59 PM
>>>>         To: MapGuide Users Mail List
>>>>         Subject: RE: [mapguide-users] OGR and MGOS
>>>>         Edit providers.xml and then restart the server (I assume you
>>>>         put the DLL in the /FDO/bin that belongs to the server). Then
>>>>         it should show up in Studio. If it does not, check the dll
>>>>         dependencies using depends or something...
>>>>         As far as Write goes, it depends what you mean by write.
>>>>         Insert, Update, Delete, Create Layer?
>>>>         Traian
>>>>         Chris Gountanis
>>>>         Sent: Friday, May 11, 2007 2:48 PM
>>>>         To: 'MapGuide Users Mail List'
>>>>         OK I grabbed this version
>>>>         what is the proper procedure. I edited the provider.xml file.
>>>>         Same exact thing I did for Map 2008 and it worked.
>>>>         Also is there a Read/Write solution to OGR?
>>>>         Chris
>>>>         Traian Stanev
>>>>         Sent: Friday, May 11, 2007 1:41 PM
>>>>         In Studio, create a New Data Connection. It will show a list
>>>>         of providers including the OGR provider. When you press on
>>>>         that, it will bring up a connection editor dialog that lets
>>>>         you set the OGR connection string. If the provider does not
>>>>         show up in the list, then it is not installed correctly on the
>>>>         server.
>>>>         Traian
>>>>         Chris Gountanis
>>>>         Sent: Friday, May 11, 2007 2:17 PM
>>>>         Subject: [mapguide-users] OGR and MGOS
>>>>         I have used the OGR in Map 2008 just fine. I want to know how
>>>>         to use the OGR FDO in MapGuide OS. Studio won't show the data
>>>>         type. Do you have to set the resource manually using the web
>>>>         tier? If so what is an example of the XML?
>>>>         Thanks!
>>>>         Chris
>>>>         _______________________________________________
>>>>         mapguide-users mailing list
>>>>         mapguide-users at lists.osgeo.org
>>>>         http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>     You snooze, you lose. Get messages ASAP with AutoCheck
>>>> <http://us.rd.yahoo.com/evt=47959/*http://advision.webevents.yahoo.com/mailbeta/newmail_html.html>
>>>>     in the all-new Yahoo! Mail Beta.
View this message in context: http://www.nabble.com/OGR-and-MGOS-tf3728865s16610.html#a11025101
