[mapguide-users] New user - mapagent not functioning
Dave Wilson dave.wilson at autodesk.com
Fri Jun 8 10:52:43 EDT 2007
Double check your configuration in Site Admin for WMS/WFS.
Ensure the server name and port are correct. Localhost should work for
your local preview, but not from any other machine.
Regards,
Dave
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Eric Bickle
Sent: Friday, June 08, 2007 12:27 AM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] New user - mapagent not functioning
Ahhh you were right - the mapagent does work with the sample parameters
(/mapagent.fcgi?OPERATION=ENUMERATERESOURCES&VERSION=1.0.0&LOCALE=en&RES
OURC
EID=Library://&TYPE).
That said, when I use MapGuide Studio (evaluation) I still can't preview
any
layers or maps - it just renders as blank. Same thing if preview a map
as
ajax.
-Eric
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Thursday, June 07, 2007 11:11 PM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] New user - mapagent not functioning
Are you just invoking mapagent as specified?
(http://localhost/mapguide/mapagent/mapagent.fcgi?) or have you included
parameters. I don't think mapagent does anything without some
parameters.
- Jackie
Eric Bickle wrote:
> I tried installing and configuring MapGuide Open Source today on a
Windows
> 2000 Server with IIS 5.
> Everything went fine - installed both the server and website
extensions
> with
> no errors. I can reach the administrative interface and configure
> server-wide settings.
> However, when I access
http://localhost/mapguide/mapagent/mapagent.fcgi? I
> get a blank page. No content returned at all (not even an XML
> declaration),
> and no errors. I verified the fastcgi mapping is in place and it
appears
> correct.
> Is there something that I'm missing? I'm able to create WMS
connections
> and
> upload SHP files, but any sort of preview of the data (layers, maps,
etc)
> just shows a blank white window.
> Thanks,
> Eric
> mapguide-users mailing list
View this message in context:
http://www.nabble.com/New-user---mapagent-not-functioning-tf3887632s1661
0.ht
ml#a11021053
