[mapguide-users] Instructions and modifications to build MGOS 1.1.0on Debian as non-root
Chris Gountanis cgountanis at mpower-tech.com
Fri Jun 8 11:53:54 EDT 2007
Hopefully they will look at posts like these or mine earlier from Gentoo and
make the installer more compatible. I think the major issue is GCC versions.
Right now it works perfectly on CentOS 4.X (RHEL Redhat Enterprise Linux)
with no modifications for those that don't have time to tweak.
Chris
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Alexandre
Leroux
Sent: Friday, June 08, 2007 10:08 AM
To: MapGuide Users Mail List
Subject: [mapguide-users] Instructions and modifications to build MGOS
Hi list,
I want to share with you the instructions and modifications required to
build MGOS 1.1.0 on Debian as non-root. We have not made extensive
tests, but it seems to work entirely. Some of the modifications below
are required to build MGOS on Debian even as root.
This comes from one of my colleagues, not myself (I haven't got the time
yet to play with MGOS). There's some additions in there that could be
added in the source code. These instructions could also be copied to a
wiki or somewhere where people would look for these.
Don't hesitate to provide feedback.
Thanks!
Alex
build-install notes for MGOS-1.1.0
(with FDO-3.2.0,
      jdk1.5.0_11,
      php-5.0.5,
      apache-httpd-2.0.55,
      tomcat-5.5.12 and
      jakarta-tomcat-connectors-1.2.15 )
on a Debian Sarge 3.1 local linux machine using GCC 3.3.5 (Debian
1:3.3.5-13).
1). install jdk1.5.0_11 locally ( in <MGOS local path> ex.
/data/anUser/somewhere/MGOS )
    cd <MGOS local path>
    extract jdk.5.0_11 with the automated installer
jdk-1_5_0_11-linux-i586.bin as follows:
        <parent path to jdk.5.0_11 installer
executable>/jdk-1_5_0_11-linux-i586.bin
    and set JAVA_HOME env. variable:
        export JAVA_HOME=<MGOS local path>/jdk1.5.0_11
2). apache-php-tomcat: ( tar archive mapguideaptinstaller-1.1.0.tar.gz )
    tar -zxvf <parent path to archive>/mapguideaptinstaller-1.1.0.tar.gz
    modify script build_apt.sh:
        -> change variable INSTALLDIR to <MGOS local path>/mgos
        -> in php build procedure -> replace --with-curl by --without-curl
    launch build_apt.sh with the option --with-tomcat
    if everything went well then:
    Add command "setEnv PHPRC <MGOS local
path>/mgos/webserverextensions/php/lib"
    to apache2 conf. file <MGOS local
path>/mgos/webserverextensions/apache2/conf/mapguide.conf
    ( This will ensure that php config. file php.ini will be found by php
scripts called
      by http requests ... )
    add these three export commands
        export JAVA_HOME=<MGOS local path>/mgos/jdk1.5.0_11
        export LD_LIBRARY_PATH=<MGOS local
path>/mgos/webserverextensions/lib:<local path>/mgos/lib:$LD_LIBRARY_PATH
        export JAVA_OPTS="-Djava.library.path=$LD_LIBRARY_PATH"
    to the tomcat startup script <MGOS local
path>/mgos/webserverextensions/tomcat/bin/startup.sh and
    add the single export command
    to the tomcat shutdown script <MGOS local
path>/mgos/webserverextensions/tomcat/bin/shutdown.sh
3). FDO:
    extract all FDO tar.gz archives as follows :
    tar -zxvf <parent path to FDO tar archives>/fdo-3.2.0.tar.gz
    tar -zxvf <parent path to FDO tar archives>/fdosdf-3.2.0.tar.gz
    tar -zxvf <parent path to FDO tar archives>/fdoshp-3.2.0.tar.gz
    tar -zxvf <parent path to FDO tar archives>/fdogdal-3.2.0.tar.gz
    tar -zxvf <parent path to FDO tar archives>/fdowfs-3.2.0.tar.gz
    tar -zxvf <parent path to FDO tar archives>/fdowms-3.2.0.tar.gz
    cd OpenSource_FDO
    modify setenvironment.sh file as follows:
          -> replace line mkdir -p /usr/local/fdo-3.2.0/lib
                          by
                          mkdir -p <MGOS local path>/fdo-3.2.0/lib
          -> replace line export
LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/fdo-3.2.0/lib
                          by
path>/fdo-3.2.0/lib:$LD_LIBRARY_PATH
    include the file contents in your env.
    . setenvironment.sh
    modify script build_thirdparty.sh as follows:
          -> replace aclocal by aclocal-1.8
          -> replace automake by automake-1.8
          -> ./configure becomes ./configure --prefix=<MGOS local
path>/fdo-3.2.0
    add the missing include command -I$(FDOTHIRDPARTY)/libcurl/include in
INCLUDES
    directives in file <MGOS local
path>/OpenSource_FDO/Utilities/OWS/Src/Makefile.am
    build_linux.sh -> replace aclocal by aclocal-1.8
                   -> ./configure becomes ./configure --prefix=<local
path>/fdo-3.2.0
                   -> replace all /usr/local path definition with <local
path>
    repeat the last step for all build_linux.sh scripts in all
sub-directories of OpenSource_FDO/Providers
    ***** IMPORTANT: Unfortunately the file <MGOS local
path>/fdo-3.2.0/lib/providers.xml installed
                     automatically by make install have the path
/usr/local/fdo-3.2.0/lib hard
                     coded in it so we must replace all lines containing
/usr/local to <local path>
                     otherwise mapguide server won't find the FDO providers
libraries ( which are
                     essential to get mapguide server doig something
useful... )
4). mapguide-1.1.0 :
    directory <MGOS local path>/mapguide-1.1.0
    in script build_oem.sh -> put the lines
                              export AUTOMAKE=/usr/bin/automake-1.8
                              export ACLOCAL=/usr/bin/aclocal-1.8
                              at the beginning of the script.
                           -> change INSTALLDIR variable to <MGOS local
path>/mgos
                           -> Build CPPUNIT 1.9.14 section ( function
build_cppunit )
                                 Add the lines
                                 sh rm -f aclocal.m4
                                 sh libtoolize --copy --force
                                 just before the ./configure command in
build_cppunit function
                           -> launch build_oem.sh
    after build_oem.sh has completed successfully do in order:
    cd in <MGOS local path>/mapguide-1.1.0/Oem/gdal-1.3.0/port
    modify header file cpl_multiproc:
       add the macro name CPL_C_START just before the line
       void CPL_DLL * CPLGetTLS( int nIndex );
       add the macro name CPL_C_END just after the line
       void CPL_DLL CPLCleanupTLS();
    this will ensure that these functions will be treated as C functions
names for
    the linking stage. ( otherwise C++ symbols are produced and the linking
stage
    of the mapguide server fails ... )
    cd in <MGOS local path>/mapguide-1.1.0 and do the usual stuff but
    with aclocal-1.8 and automake-1.8 and some options passed to
    configure.
    aclocal-1.8 ( forget about warnings ... )
    libtoolize --force
    automake-1.8 --add-missing --copy
    autoconf
    configure --prefix=<MGOS local path>/mgos \
              --with-fdo-include=<MGOS local path>/fdo-3.2.0/include \
              --with-fdo-lib=<MGOS local path>/fdo-3.2.0/lib
--without-python
    make
    make check
    make install
Alexandre Leroux, M.Sc., Ing.
Environnement Canada / Environment Canada
Centre météorologique canadien / Canadian Meteorological Centre
Division de la réponse aux urgences environnementales /
Environmental Emergency Response Division
alexandre.leroux at ec.gc.ca
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
