[mapguide-users] mapguide library!
Kenneth, GEOGRAF A/S ks at geograf.dk
Sun Jun 10 04:52:11 EDT 2007
It is also possible to load/save the xml definitions by using the
GetResource and SetResource functions avalible in the MapGuideAPI.
If you want to examine the data, there are XSD files in the MapGuide
installation directory that defines the layout for the XML of the
different resources.
There is a testform that allows you to interact directly with the
mapagent at:
http://localhost/mapguide/mapagent/index.html
Regards, Kenneth, GEOGRAF A/S
James Card skrev:
> On Sat, 09 Jun 2007 04:14:37 -0700, Mansoureh Sadrykia
> <m_sadrykia at yahoo.com> wrote:
>> I have a question, Is it possible to access the files of library of
>> localhost - as it's seen in mapguide studio (like web layouts, map
>> definitions,...)- from outside mapguide studio?
> No. Not in any practical manner. The only practical access to that
> data outside of Studio is through the mapagent interface. It would not
> be difficult to build a script that extracts all the LayerDefinitions
> and such to separate XML files.
