[mapguide-users] SetSelectionXML on layer from database (PostgreSQL->PostgGIS)
Maciej Skorczewski maciej.skorczewski at procad.pl
Mon Jun 11 08:18:03 EDT 2007
hi Kenneth!
this is big problem to me because all data are stored in
postgis/postgresql and user can edit it or delate from web browser...
so all data are in one place...
this is my idea:
1. all date are in one database (OGR provider  is "adapter" to this
database - know in MG as "source" for layer)
2. i create many layer whit filter to data ex: level=1, level=2, name=''
etc.
3. i call created layer and make operation on database (change
atributes, delete or even create new shape!), so after refresh  i see it
on web browser  and data source are update for another aplication (like
MAP 3D if you must make more complex operation.).
so know i am i BIG DOT...
maciek
Kenneth, GEOGRAF A/S pisze:
> I can see no fault in your code.
> I don't think there is a workaround to SetSelectionXML, other than
> perhaps creating a temp layer, and setting the filter attribute to match
> the selection.
> And I agree, the bug you reported is quite annoying. There is no easy
> fix, as I see it.
> Traian suggested using some of the Fdo intersection code, but I am not
> familliar enough with Fdo to do that.
> Until the OGR provider gets fixed, you can try the Fdo2Fdo converter,
> and get SDF files out of whatever OGR data you have.
> Regards, Kenneth, GEOGRAF A/S
