[mapguide-users] Desktop implementation of MapGuide
Kneo kalpesh at pie-solution.com
Mon Jun 11 22:58:04 EDT 2007
If this app has to run while being online, there is no distinct advantage, is
there ? The killer app would allow you to connect to the server at the
start, fetch the map and then use it offline. Or better still, get the
layers from various servers and combine it in a single map on the desktop
application
Kenneth, GEOGRAF A/S wrote:
> Sort of...
> The current implementation of the API uses a local tcp connection to
> connect to the server.
> You may be able to fix this by supplying a custom "webconfig.ini", where
> you change the IP adress, but it might be a problem if you intend to use
> it outside of the LAN.
> You will not be able to use the MapGuide API in offline mode.
> Also, you will have to implement most of the functionality yourself
> (zoom, pan, etc), as that is written in AJAX.
> There exists functionality to get raster map, set selection etc, but it
> is still raster.
> You might be able to get away with embedding a web browser (like studio
> does), or simply use the DWF viewer as an ActiveX control.
> These will have to run online though.
> You can also copy all data from the server, using Fdo, and storing it
> locally in SDF files. That should give nice speed, but you will have to
> render the map yourself.
> I'm not sure how much info the standard DWF map contains, but you might
> convince the server to give you a full DWF copy of the map. If you have
> that, you should be able to use the DFW viewer in offline mode.
> Regards, Kenneth, GEOGRAF A/S
> Kneo skrev:
>> Would it be possible to have a desktop implementation of MapGuide
>> (offline
>> viewing) ? Basically, the desktop application created in VB.net will
>> connect
>> to a set of servers to fetch the map and then allow the user to browse it
>> offline. Since the map is now copied to the local desktop, the speed and
>> flexibility will be immense.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Desktop-implementation-of-MapGuide-tf3900680s16610.html#a11072163
