[mapguide-users] OGR / GEOS selection problem
Traian Stanev traian.stanev at autodesk.com
Tue Jun 12 10:25:15 EDT 2007
Hi.
I checked in a temporary fix to this problem. I simply warped one of the coordinates of the input polygon by 10^-10. This is sufficient to make OGR call GEOS to compute the exact intersection. Selection should work correctly now in the AJAX viewer.
I have not posted a compiled DLL yet, so Kenneth feel free to do so, (-:
Traian
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Traian Stanev
Sent: Thursday, June 07, 2007 3:46 PM
To: MapGuide Users Mail List; MapGuide Users Mail List
Subject: RE: [mapguide-users] OGR / GEOS selection problem
Hi Kenneth,
Thanks for tracking this down. I would try to fix this by bypassing Geos. FDO has utility code that can check for an intersection. We could take the BBOX result and pass that through a real intersection check on the provider side. This way the intersection check would be performed only on geometries that are close enough to the query polygon so the overhead should not be too bad.
Traian
	-----Original Message-----
	From: mapguide-users-bounces at lists.osgeo.org on behalf of Kenneth, GEOGRAF A/S
	Sent: Thu 6/7/2007 2:54 AM
	Cc:
	Subject: [mapguide-users] OGR / GEOS selection problem
	Maciej previously reported problems with the OGR provider using PostGIS.
	The problem is with the OGR provider.
	Se the Trac ticket for details:
	http://trac.osgeo.org/mapguide/ticket/172
	I have posted some follow up on the issue, but in hope someone knows a
	lot about GEOS, I'm also posting it here:
	I have been examining the problem, using a custom build of the OGR
	provider. It is true that without GEOS support in OGR, the Intersect
	only does a BBOX check.
	However, merely enabling GEOS will not work, as the viewer sends a
	square that is orthogonal to the axes (like a BBOX). The GEOS library
	will interpret this as another BBOX, and only perform the BBOX check
	anyway.
	When I change the polgyon sent from the viewer to a triangle, it takes
	22 seconds to calculate the Intersects result with a polygon with 8000
	linesegments. I have a 2+ GHz machine.
	It seems that GEOS always builds a full intersection matrix, before
	returning the result. This is obviously not optimal for a simple hit
	test. Even with this knowledge, I still don't see how it can take 22
	seconds to calculate 8000 * 3 intersections.
	Can someone explain this, or how to fix it?
	Regards, Kenneth, GEOGRAF A/S
	mapguide-users mailing list
	mapguide-users at lists.osgeo.org
	http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070612/bff3e348/attachment.html
