[mapguide-users] RE: MapGuide Service Stops after sometime.
Kenneth, GEOGRAF A/S ks at geograf.dk
Wed Jun 13 03:18:17 EDT 2007
You can set that in the Service settings, click:
Start -> Control Panel -> Administrative Tools -> Services
Locate the "MapGuide Server" entry, right click it, select "Properties".
Then select the tab "Recovery", and set these settings as desired.
You should not set "restart after" to anything less than one minute.
Regards, Kenneth, GEOGRAF A/S
Jim O'Leary skrev:
> How do you set the MapGuide server to auto restart? I don't see any such
> setting in the mapadmin.
> Thanks.
> Willem Schwarte wrote:
>> We also have this problem, you can try to set the service to auto
>> restart.
>> Willem
>> -----Oorspronkelijk bericht-----
>> Van: Sajith S [mailto:sajith at kalkitech.com]
>> Verzonden: donderdag 20 juli 2006 6:19
>> Aan: MGOS Users
>> Onderwerp: [mapguide-users] MapGuide Service Stops after sometime.
>> Hi,
>> I am new to MapGuide Open Source Server.
>> I setup the mapGuide Server in a windows 2000 Prof. environment with
>> Ajax
>> viewer.
>> The sample provided along with the mapguide ,Sheboygan is working fine.
>> Now i am creating my own application using Autodesk Mapguide Studio 2007
>> Preview
>> MapGuide Server version is 1.0.0.16407
>> Now i am facing some problems, i created the my own application which
>> uses
>> SHP files.
>> Now the Ajax Viewer displays the Map etc. But after sometime after 10-15
>> minutes Mapguide Server Service pop-up some error which is getting
>> logged in
>> the event logger. After this error my application stops working if i
>> stop
>> and start the service then it starts again.
>> Error shown in the System log of event viewer is given below.
>> Application popup: MgServer.exe - Application Error : The instruction at
>> "0x00fcfd2e" referenced memory at "0x00000000". The memory could not be
>> "read".
>> thanks
>> Sajith S
>> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>> For additional commands, e-mail: users-help at mapguide.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070613/b3307723/attachment.html
