[mapguide-users] mapguide1.1.0 compile error on linux: conflict libxerces-c version
Audaire David DAUDAIRE at ares.fr
Wed Jun 13 11:45:59 EDT 2007
and both are in the archive.
here are all the paths
/opt/archive_install_mapguide/OpenSource_FDO/Thirdparty/apache/xml-xerces/c/obj/libxerces-c.so.25.map
/opt/archive_install_mapguide/OpenSource_FDO/Thirdparty/apache/xml-xerces/c/lib/libxerces-c.so.25
/opt/archive_install_mapguide/OpenSource_FDO/Thirdparty/apache/xml-xerces/c/lib/libxerces-c.so.25.0
/opt/archive_install_mapguide/mapguide-1.1.0/Oem/dbxml-2.2.13/install/lib/libxerces-c.so.27
/opt/archive_install_mapguide/mapguide-1.1.0/Oem/dbxml-2.2.13/install/lib/libxerces-c.so.27.0
/opt/archive_install_mapguide/mapguide-1.1.0/Oem/dbxml-2.2.13/xerces-c-src/obj/libxerces-c.so.27.map
/opt/archive_install_mapguide/mapguide-1.1.0/Oem/dbxml-2.2.13/xerces-c-src/lib/libxerces-c.so.27
/opt/archive_install_mapguide/mapguide-1.1.0/Oem/dbxml-2.2.13/xerces-c-src/lib/libxerces-c.so.27.0
/usr/local/mapguideopensource/lib/libxerces-c.so.27
/usr/local/mapguideopensource/lib/libxerces-c.so.27.0
/usr/local/fdo-3.2.0/lib/libxerces-c.so.25
/usr/local/fdo-3.2.0/lib/libxerces-c.so.25.0
yagbu chen wrote:
> Hi,
>      I got some errros when I tried to compile mapguide1.1.0  on my SUSE
> 10:
> "mapguide-1.1.0
> /Server/src/Services/Resource/.libs/libMgServerResourceService.so,
> may conflict with libxerces-c.so.25
> /home/mapguide/mapguide-1.1.0
> /Server/src/Services/Resource/.libs/libMgServerResourceService.so:
> undefined reference to `MgXmlUtil::GetElementValue(xercesc_2_7::DOMNode*,
> char const*, bool&, bool)'
> undefined reference to `MgXmlUtil::GetElementNode(xercesc_2_7::DOMNode*,
> char const*, bool)'
>      It seems that mapguide-1.1.0 depends on libxerces-c.so.27 while
> FDO-3.2.0 depends on libxerces-c.so.25 .    When link mapguide with FDO
> library, version conflict error  happens.
>      Has anybody compiled mapguide-1.1.0 on linux successfully?   Please
> help me if you has any suggestion.
> Thanks
> yabgu
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/mapguide1.1.0-compile-error-on-linux%3A-conflict-libxerces-c-version-tf3893325s16610.html#a11102434
