[mapguide-users] FDO PostGIS provider. Was: OGR Provider
Jose Manuel C G gis at mapas-sll.com
Thu Jun 14 02:53:50 EDT 2007
According to this TODO
http://svn.osgeo.org/fdo/trunk/Providers/PostGIS/Src/TODO.txt link , It
isn't implemented (operations on geometries: select/insert/update/delete).
Anyway, now I can fill the form on Map 2008, and click on connect. But I get
the next error:
The describe schema command failed for '' schema.
The execution of describe schema operation failed.
The Spatial Reference System for SRID=ㄭഀ宐৖뚐ࣾ⛨ড় not found.
With OGR works, and the schema (public) is called '21002parcelas'.
What's wrong?
View this message in context: http://www.nabble.com/Bad-Performance-using-dwf-Files-tf3906287s16610.html#a11114898
