[mapguide-users] DWG file No Rotation on Text
Berdel, Brian brian.berdel at mcmtrans.com
Fri Jun 15 12:21:04 EDT 2007
Using 1.2 RC1...this was not a problem in the beta.  When I import a
layer from a DWG file (It is a Street Label Layer). There is no rotation
on the text.  Anyone else experiencing this? I tried it a few times.
Brian  Berdel
McMahon Associates, Inc.
p: 215.283.9444
www.mcmtrans.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
Sent: Friday, June 15, 2007 11:06 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Problems with data external join
Yes, it's a known issue:
http://trac.osgeo.org/mapguide/ticket/146
http://trac.osgeo.org/mapguide/changeset/1749
http://trac.osgeo.org/mapguide/changeset/1750
Please try with RC1.
Jason
Subject: [mapguide-users] Problems with data external join
I have created a feature source from a SDF file, and i have join datas
from a oracle database with ODBC FDO driver. I'm using mapguide
opensource 1.2 beta with mapguide studio 2007. When i select a feature
on the map all the datas appears in the properties panel. But when i
want to show a label on the feature, for exemple their ID, the data is
incorrect. For example : the room number 12 (data in the properties
panel), the label which shows the id is : 14, i have the same problem
with filter.
Is it a known problem ???
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
