[mapguide-users] RE: MGOS 1.2 RC1 & Mapguide Studio 2007 Enterprise
WCT stephen.park at westerncorrosion.com
Fri Jun 15 12:36:12 EDT 2007
Thanks for the heads-up on the patch.
MapAdmin was working satisfactorily, I was able to load a package using the
MapAdmin feature. But, MapAgent/index.html is giving "Page Not Found" when
trying to run the Resource Enumeration tests et al. Looking in IIS
configuration I see that .fcgi had not been registered against
isapi_fcgi.dll under mapagent application for some reason??
I manually registered it as per instructions on page 18 of the 1.1 Install
Guide
http://mapguide.osgeo.org/files/mapguide/docs/InstallConfigureMgOpenSourceOnWindows.pdf
And I'm back in business. Webstudio opens the library correctly now. Thanks
very much for your help.
Regards,
Steve
Andy Morsell wrote:
> You have to install a patch for Studio in order for it to be able to
> communicate with 1.2.0 sites.  A link to it can be found at the very
> bottom
> of this page under the "Links to Related Applications and Tools"
> http://mapguide.osgeo.org/download1.2.0.html
> You may have something else going based on your description.  It sounds
> like
> you are using the IIS / .NET install so you do not need to be specifying
> port 8008.  It should just be http://localhost/mapguide
> Do you get anything here: http://localhost/mapguide/mapagent/index.html or
> here http://localhost/mapguide/MapAdmin/Login.php ?
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of WCT
> Sent: Thursday, June 14, 2007 4:48 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] MGOS 1.2 RC1 & Mapguide Studio 2007 Enterprise
> Hi,
> I am attempting to take MGOS 1.2 RC1 for a spin. Is connection from
> Mapguide
> Studio 2007 Enterprise (1.0.0.17864) to MGOS 1.2 RC1 a supported
> configuration? I keep getting "Cannot connect to the specified site URL"
> errors both on port 80 and 8008.
> I am having similar problems connecting with WebStudio that ships with 1.2
> RC1. I am running IIS / .Net configuration from the install. When I
> attempt
> to connect to http://127.0.0.1:8008/mapguide, the tool gives no feedback:
> login dialog clears but no assets show up in the Site Explorer.
> If I run iisweb /query I see only the default site on port 80, nothing on
> 8008. Can anyone suggest some trouble-shooting steps? This machine
> previously had Mapguide Enterprise 2K7 installed and I suspect the web
> server extensions may have become mis-configured somewhere along the way.
> http://www.nabble.com/MGOS-1.2-RC1---Mapguide-Studio-2007-Enterprise-tf39250
> 10s16610.html#a11130936
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/MGOS-1.2-RC1---Mapguide-Studio-2007-Enterprise-tf3925010s16610.html#a11143286
