[mapguide-users] Producing High Resolution images using rendering service
Simon Hope SimonH at geobiz.co.nz
Thu Jun 21 20:51:40 EDT 2007
Hi
I've got a client who is very interested in developing a site using
MapGuide Open source and they have a requirement to produce a map image
output into a PDF but the quality of the image is important - i.e.
suitable to print on a 600dpi printer.
I've looked over the documentation and the Rendering Service seems to
cater for map image output however it's not clear on what quality you
can get using this - does anyone have any experience of using the
rendering service in this way and could answer these questions:
Can the rendering service be used to output map images at a higher
quality by specifying resolution?
If the map image resolution cannot be set -is there any restriction on
the size of the image exported using the rendering service (i.e. produce
a large image (width x height) and reduce this to fit into the PDF -
therefore increasing the quality?
Thanks
Simon
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070622/1adf25e3/attachment.html
