[mapguide-users] Producing High Resolution images using
Simon Hope SimonH at geobiz.co.nz
Thu Jun 21 22:14:05 EDT 2007
Thanks for the info - very useful.
>From reading the web API documentation the use of both width and height
is clear (via the MgRenderingService class) - however defining dpi as a
property of the image is not - I assume this is a property of the map
itself exposed via GetDisplayDpi?
If this is the case how is dpi on the map set?
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070622/a5f07719/attachment.html
