[mapguide-users] MapGuideJavaApi package java source codewhereabouts?
Rex Szeto (Intern) Rex.Szeto at autodesk.com
Fri Jun 22 13:06:01 EDT 2007
HI Brendan,
MapGuideJavaApi is a .jar file located in ur /www/WEB-INF/lib folder.
Open it with winzip and you can see the compiled Java classes.
Rex
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Brendan
Graham
Sent: Friday, June 22, 2007 10:57 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] MapGuideJavaApi package java source
codewhereabouts?
In "/WebServerExtensions/www/mapviewerjava/common.jsp", a reference to a
static method in the package "MapGuideJavaApi" is made as follows:
void InitializeWebTier() throws MgException
    // Initialize web tier with the site configuration file.  The config
    // file should be in the same folder as this script.
    String realpath = getServletContext().getRealPath("/");
    String configPath =  realpath + "webconfig.ini";
    MapGuideJavaApi.MgInitializeWebTier(configPath);
QUESTION: Where can I find the java code for the "MapGuideJavaApi"
package?
uSys Integral
Brendan Graham, CTO
e-mail: info at usysinc.com
Tel# 305-793-3778
  _____
Make every IM count. Download Messenger and join the i'm Initiative now.
It's free. <http://g.msn.com/8HMAENUS/2755??PS=47575>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070622/e92551c8/attachment.html
