[mapguide-users] RE: RE: RDBMS: Can't connect to MySQL Server
Dhirendra Kumar dhirendra.mgos at gmail.com
Sat Jun 23 01:59:04 EDT 2007
Hi Dave
Thankyou for replay, My Problem get solve. 127.0.0.1 IP Adress and localhost
is also working fine. Dave i have lots of points (Latitude and Longitude)
with their corresponding values for Polyline and points and polygon but it
is impossible to enter every values from MySQL Prompt using Insert command,
You have any idea how to insert all values in MySQL database without using
Insert Command. One way is inserting values using shp2MySQL But ihave no
idea how to upload using this. If you have any idea then please help me.
Thankyou in Advance.
Regards,
Dhirendra Kumar
Dave Wilson-3 wrote:
> If I understand correctly MySQL is on your local machine whose IP
> address keeps changing?
> Can you try using 127.0.0.1 as the IP address to your MySQL instance?
> Dave
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dhirendra
> Kumar
> Sent: Friday, June 22, 2007 4:00 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] RE: RDBMS: Can't connect to MySQL Server
> Hi Dave,
> Thankyou for helping once again. Actually my problem is MySQL and
> mapguide
> connection (FDO). My computer generate IP Address Dyanmically when
> computer
> generates new IP Address then Previous created Layers not display and
> generate ERROR!!
> An exception occurred in FDO component.
> RDBMS: Can't connect to MySQL server on '102.168.1.13' (10060)
> Please help me. Anayway to assign MySQL server IP addres Dyanmically ?
> regards,
> Dhirendra kumar
>> What version is your MySQL database? The later FDO only supports
> version
>> 5.022 through about 5.027.
>> Regards,
>> Dave
>> Kumar
>> Sent: Wednesday, June 20, 2007 11:56 PM
>> Subject: [mapguide-users] RDBMS: Can't connect to MySQL Server
>> Hi All,
>> Using MGOS 1.1.0, FDO 3.2, MySQL 5.0, WinXP...
>> I have success with setting up a MySQL connection for an application
> on
>> my
>> local drive. Now that I have 'moved' the application to another
> machine.
>> But
>> now i getting a MySQL connection ERROR!!
>> The feature source is invalid resion:
>> An exception occured in FDO component.
>> RDBMS: Can't connect to MySQL Server on '192.168.1.130' (10060)
>> I changed new machine IP Address also in Datasource but problem is
> still
>> same. Any way to set IP Address Dynamically ? I think using this way
> my
>> problem get solve and i can move Application to any machine or Dynamic
>> enable IP Address machine. But i have not idea how to do this, If
> anyone
>> have idea about this than please help me. Thankyou in advance.
>> Regards,
>>  Dhirendra Kumar
>> View this message in context:
> http://www.nabble.com/RDBMS%3A-Can%27t-connect-to-MySQL-Server-tf3956684
>> s16610.html#a11227075
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> s16610.html#a11248831
View this message in context: http://www.nabble.com/RDBMS%3A-Can%27t-connect-to-MySQL-Server-tf3956684s16610.html#a11263598
