[mapguide-users] RE: Several small lay-out questions
martijni mis at gemeentehulst.nl
Wed Jun 27 10:54:18 EDT 2007
Hey James,
I'm looking at it, but wasn't there an easier way to just get rid of the
decimals? Noone had the same small problems like me or found a solution for
any my problems?
James Card wrote:
> On Mon, 25 Jun 2007 04:23:25 -0700, martijni <mis at gemeentehulst.nl> wrote:
>> I did what Jackie said by giving up 0+<property name> (like tanknr) in
>> the feature label box (theme). Then it shows no decimals in the map
>> indeed, but I don't want the decimals in the properties. I tried to add
>> it in the tooltip. Maybe I misunderstood and entered it on the wrong
>> place?  :)
> The properties display is controlled by the SetProperties() function in
> \www\viewerfiles\propertyctrl.templ. Of course, if you modify that file
> you'll have to reapply your modifications after each upgrade -- it is
> probably better to override that function with one of your own in your
> wrapper files.
> James Card
> 209-578-5580
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Several-small-lay-out-questions-tf3882273s16610.html#a11326084
