[mapguide-users] RE: RE: RE: RE: RDBMS: Can't connect to MySQL Server
Dhirendra Kumar dhirendra.mgos at gmail.com
Fri Jun 29 02:22:29 EDT 2007
Hi JasonBirch,
I tryed to import shp file in MySQL using FDO2FDO but till now i am not
Success, I want to ask one importatnt qustion to you that i have your gt
Query and i want to use your query with this FDO sample Application than i
see every thing is working fine, i can see layers in Layers combo box, their
property in property box, operator combo box,output property in output
property box.  But when after inserting value in value box, and clicking on
Execute button then I not getting any result in ? Output property box, So
please help me. Thankyou in Advance.
Regards,
Dhirendra Kumar
JasonBirch wrote:
> There isn't a dedicated task for this but you should be able to transfer
> between any vector-based FDO data source.
> - Add the MySQL provider dlls (including MySQL DLLs) to the fdo2fdo
> application
> - Edit the providers.xml file to include the MySQL provider
> - Use the "Connections List" to add and test a connection to your MySQL
> database
> - Use either the generic "Copy Fdo2Fdo" task, or the Schema Manager /
> Copy Task Manager tools
> If this still doesn't work, I'm afraid that I don't know any other ways
> to write to the MySQL format that FDO uses.
> Jason
> -----Original Message-----
> From: Dhirendra Kumar
> Subject: [mapguide-users] RE: RE: RE: RDBMS: Can't connect to MySQL
> Server
> I Download FDO2FDO but there is not any option for SHP to MySQL
> connectivity, forcebly when i use option SHP to Oracle for MySQL
> Connectivity then, system return Oracle TNS Error. JasonBirch, give me
> another idea if possible. Thankyou in Advance..
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/RDBMS%3A-Can%27t-connect-to-MySQL-Server-tf3956684s16610.html#a11355627
