[mapguide-users] Clear Selection
RichBauer rdbauer at gmail.com
Fri Jun 29 16:17:54 EDT 2007
Has anyone experienced the problem of when say a parcel (polygon) is selected
and the properties display just fine and then you use the "Clear Selection"
command from the right-click menu, the highlighting clears, but the
properties window does not clear?  If so, is there a way to fix it?  It is
not a big deal, just for cleanliness.  Thanks.
Rich
View this message in context: http://www.nabble.com/Clear-Selection-tf4001770s16610.html#a11366536
