[mapguide-users] How to add WMS (Transparent) layer to MapGuide?
Patrick Tsang pt at pat.ca
Sat Jun 30 19:05:09 EDT 2007
Hi All,
I want to add WMS layer on the fly
not through MapStudio. I am able to add WMS layer on the fly but the layer
come back is not
transparent but i cannot figure out how to request the layer as
transparent... here is my code (C#):
        private string formatWMSProviderXml =
            "<?xml version=\"1.0\" encoding=\"utf-8\"?>" +
System.Environment.NewLine +
            "  <FeatureSource
xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\";
xmlns:xsd=\"http://www.w3.org/2001/XMLSchema\";
xsi:noNamespaceSchemaLocation=\"FeatureSource-1.0.0.xsd\">" +
            "    <Provider>OSGeo.WMS</Provider>" +
            "    <Parameter>" + System.Environment.NewLine +
            "      <Name>FeatureServer</Name>" + System.Environment.NewLine
            "      <Value>{0}</Value>" + System.Environment.NewLine +
            "    </Parameter>" + System.Environment.NewLine +
            "  </FeatureSource>";
        private string formatWMSLayerXml =
            "<?xml version=\"1.0\" encoding=\"UTF-8\"?> " +
            "  <LayerDefinition
xsi:noNamespaceSchemaLocation=\"LayerDefinition-1.0.0.xsd\"
version=\"1.0.0\"> " + System.Environment.NewLine +
            "    <GridLayerDefinition> " + System.Environment.NewLine +
            "      <ResourceId>{0}</ResourceId> " +
            "      <FeatureName>WMS_Schema:{1}</FeatureName> " +
            "      <Geometry>Raster</Geometry> " +
            "      <GridScaleRange> " + System.Environment.NewLine +
            "        <ColorStyle> " + System.Environment.NewLine +
            "          <ColorRule> " + System.Environment.NewLine +
            "            <LegendLabel></LegendLabel> " +
            "            <Color> " + System.Environment.NewLine +
            "              <ExplicitColor>000000</ExplicitColor> " +
            "            </Color> " + System.Environment.NewLine +
            "          </ColorRule> " + System.Environment.NewLine +
            "              <ExplicitColor>FFFFFF</ExplicitColor> " +
            "        </ColorStyle> " + System.Environment.NewLine +
            "        <RebuildFactor>1</RebuildFactor> " +
            "      </GridScaleRange> " + System.Environment.NewLine +
            "    </GridLayerDefinition> " + System.Environment.NewLine +
            "  </LayerDefinition>";
        public void AddLayer(string SessionId, string ClassName, Server
Server, string MapName)
            // Create MgSiteConnection
            MgSiteConnection siteConnection = new MgSiteConnection();
            siteConnection.Open(new MgUserInformation(SessionId));
            //create the services we will use
            MgResourceService resourceService =
siteConnection.CreateService(MgServiceType.ResourceService) as
MgResourceService;
            //create the wms feature source
            // NOTES: Server.URL is something like
"http://www.geographynetwork.ca/wmsconnector/com.esri.wms.Esrimap/OBM_Full_I?request=getcapabilities&service=WMS&version=1.1.1";
            string formatedWmsProviderXml =
string.Format(formatWMSProviderXml, XmlEscape(Server.URL));
            MgByteSource wmsFeatureSourceByteSource = new
MgByteSource(System.Text.Encoding.ASCII.GetBytes(formatedWmsProviderXml),
formatedWmsProviderXml.Length);
            wmsFeatureSourceByteSource.SetMimeType(MgMimeType.Xml);
            string featureSourceName =
string.Format("Session:{0}//{1}.FeatureSource", SessionId, Guid.NewGuid());
            MgResourceIdentifier WmsFeatureSourceResourceIdentifier = new
MgResourceIdentifier(featureSourceName);
            resourceService.SetResource(WmsFeatureSourceResourceIdentifier,
wmsFeatureSourceByteSource.GetReader(), null);
            //create the wms layer
            // NOTES: ClassName is the layer name user pick from a list of
layers from the Server.URL
            string layerWmsName = ClassName;
            string formatedWmsLayerXml = string.Format(formatWMSLayerXml,
XmlEscape(featureSourceName), XmlEscape(layerWmsName));
            MgByteSource wmsLayerByteSource = new
MgByteSource(System.Text.Encoding.ASCII.GetBytes(formatedWmsLayerXml),
formatedWmsLayerXml.Length);
            wmsLayerByteSource.SetMimeType(MgMimeType.Xml);
            MgResourceIdentifier wmsLayerResourceIdentifier = new
MgResourceIdentifier(string.Format("Session:{0}//{1}.LayerDefinition",
SessionId, layerWmsName));
            resourceService.SetResource(wmsLayerResourceIdentifier,
wmsLayerByteSource.GetReader(), null);
            //get a reference to the map
            MgResourceService l_oResourceService =
MgResourceService;
            MgMap map = new MgMap();
            map.Open(l_oResourceService, MapName);
            // Add the new layer to the map's layer collection
            MgLayer newLayer = new MgLayer(wmsLayerResourceIdentifier,
resourceService);
            newLayer.SetName(layerWmsName);
            newLayer.SetVisible(true);
            newLayer.SetLegendLabel(layerWmsName);
            newLayer.SetDisplayInLegend(true);
            MgLayerCollection layerCollection = map.GetLayers();
            if (!layerCollection.Contains(layerWmsName))
                // Insert the new layer at position 0 so it is at
                // the top of the drawing order
                layerCollection.Insert(0, newLayer);
                Server.Layers.Find(delegate(Layer l) { return l.ClassName ==
ClassName; }).IsVisible = true;
            //  Save the map back to the session repository
            string mapResourceName = string.Format("Session:{0}//{1}.Map",
SessionId, MapName);
            MgResourceIdentifier mapResourceID = new
MgResourceIdentifier(mapResourceName);
            mapResourceID.Validate();
            map.Save(resourceService, mapResourceID);
            // return
            //return Server;
There has objects not defined, try to keep it short. Sorry about it...
Thanks in advance!!!
Cheers,
Patrick
View this message in context: http://www.nabble.com/How-to-add-WMS-%28Transparent%29-layer-to-MapGuide--tf4006306s16610.html#a11377823
