[mapguide-users] Mg build error on Ubuntu 6.10
Chris Gountanis cgountanis at mpower-tech.com
Fri Mar 2 11:43:52 EST 2007
Could try this:
****** Fix DWF Build SH ******
Edit build_setup.sh files with "libtoolize --copy --force" after "autoreconf
--force" (no quotes)
nano
/home/mapguide-1.1.0/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/build_set
up.sh
nano
/home/mapguide-1.1.0/Oem/DWFTK7.1/develop/global/build/gnu/dwfemap/build_set
up.sh
nano
/home/mapguide-1.1.0/Oem/DWFTK7.1/develop/global/build/gnu/dwftoolkit/build_
setup.sh
cd mapguide-1.1.0
./build_oem.sh
Chris
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of François Van
Der Biest
Sent: Friday, March 02, 2007 10:37 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Mg build error on Ubuntu 6.10
Hi list,
I'm trying to build Mg 1.1 on a Ubuntu 6.10 system
At the build_oem.sh step, compilation stops because of a switch that
seems to be interpreted as a command : -avoid-version (see log below)
I've been looking in the different Makefiles if I could spot a typo,
without success.
Any idea ?
F.
make  all-recursive
make[1]: entrant dans le répertoire «
/home/vdb/Projets/MapGuide/mapguide-1.1.0/Oem/DWFTK7.1/develop/global/src/dw
f
Making all in package
make[2]: entrant dans le répertoire «
f/package
Making all in reader
make[3]: entrant dans le répertoire «
f/package/reader
make[3]: Rien à faire pour « all ».
make[3]: quittant le répertoire «
f/package/reader
Making all in writer
f/package/writer
Making all in extensions
make[4]: entrant dans le répertoire «
f/package/writer/extensions
Making all in 6.01
make[5]: entrant dans le répertoire «
f/package/writer/extensions/6.01
make[5]: Rien à faire pour « all ».
make[5]: quittant le répertoire «
Making all in 6.0
avoid-version
../../../package/writer/extensions/6.01/libdwfpackagewriterextensions601.la
../../../package/writer/extensions/6.0/libdwfpackagewriterextensions60.la
-lz
make[5]: avoid-version : command not found
make[5]: [libdwfpackagewriterextensions.la] Erreur 127 (ignorée)
make[4]: quittant le répertoire «
f/package/writer
make[4]: *** Pas de règle pour fabriquer la cible «
../../package/writer/extensions/libdwfpackagewriterextensions.la »,
nécessaire pour « libdwfpackagewriter.la ». Arrêt.
f/package/writer
make[3]: *** [all-recursive] Erreur 1
f/package/writer
make[2]: *** [all-recursive] Erreur 1
make[2]: quittant le répertoire «
f/package
make[1]: *** [all-recursive] Erreur 1
make[1]: quittant le répertoire «
f
make: *** [all-recursive-am] Erreur 2
DWFTK 7.1: Error build failed (0).................
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
