[mapguide-users] render service
Andy Morsell amorsell at spatialgis.com
Thu Mar 8 11:06:31 EST 2007
That solution does not apply to the tile cache - only to the AJAX viewer
generated map.  There is an RFC in the works that will allow you to
designate the tile cache format as PNG or JPG.
Andy
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Maciej
Skorczewski
Sent: Wednesday, March 07, 2007 11:22 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] render service
hi Andy!
I try yours solution but in TileCache (after delete it before) MGOS still
generate PNG files.
maciek
Andy Morsell napisal(a):
> You can greatly improve the speed of a site by having MapGuide server
> generate JPG maps rather than PNG.  Unfortunately, this must be done
> on a server global basis and JPG does not look nearly as nice as PNG.
> This has a particularly favorable affect when using imagery layers in
> your map.  In my non-scientific tests, I saw individual map requests
> go from 1 MB PNG's to 75 KB JPG's.
> There are cases where you simply cannot make this setting (since it's
> global) particularly if you are using base layer tiles in your maps
> since the JPG images are not transparent and will cover your PNG
> tiles.  There is an RFC in the works that will allow the configuration
> of base layer tiles to be output as JPG images.  The map overlays
> would remain transparent PNG's but this should yield good performances
> since the PNG's are only rendered with your vector information.
> To try this, edit the RequestMapImage() function of the
> ajaxmappane.templ file and change the FORMAT parameter to JPG instead
> of PNG
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of alucas
> Sent: Wednesday, March 07, 2007 3:39 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] render service
> Hello,
> I'm testing mapguide server performance with sql server 2005 through FDO.
> One of the tasks that get more time to do is to render the png image.
> So, I think this task would be better enabling apache compression for png
images.
> What do you think about?
> http://www.nabble.com/render-service-tf3361564s16610.html#a9351254
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
