[mapguide-users] GetMapImage and GetMapTiled
Traian Stanev traian.stanev at autodesk.com
Fri Mar 9 09:46:23 EST 2007
To produce a tile, several things are done differently. Geometries are
not clipped to the viewport, in order to ensure continuity across tiles.
Label management is done differently since it has to ensure labels
behave well across tiles (.i.e you don't get half a label on one tile
and no label on the other). Also, labeling requires that a bigger view
area is requested from FDO than normal non-tiled maps. These things add
up to make performance worse.
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kencana
Sent: Friday, March 09, 2007 12:59 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] GetMapImage and GetMapTiled
Hi All,
Just find out that, getmapimage is actually a little bit faster in
generating a initial map view than getmaptiled.
I am not sure whether I am right about this or not. but if it is true,
can I
know why it is faster than maptiled?
View this message in context:
mapguide-users mailing list
