[mapguide-users] shapefile to SDF
Kori Maleski Kori.Maleski at websoftdev.com
Fri Mar 9 17:22:26 EST 2007
Autodesk MapGuide Studio will do the Shape to SDF conversion in a Load
Procedure.
http://usa.autodesk.com/adsk/servlet/index?id=7176611&siteID=123112
Otherwise you could try the Fdo2Fdo:
http://www.sl-king.com/fdo2fdo/fdo2fdo.html
Beyond that there is Autodesk Map 2007 or FME.
Cheers,
Kori Maleski
Senior Application Developer
WEBSOFT DEVELOPERS, INC.
P: (530) 759-8754 ext 114
F: (530) 759-0923
kori.maleski at websoftdev.com
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of jtby
Sent: Friday, March 09, 2007 2:04 PM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] shapefile to SDF
I only have the open source stuff I downloaded.  Is it only possible if you
purchase something?
Daniel Colby wrote:
> If you have
> Autodesk Map, you can import shape files then export them to sdf using
> the Map>Tools>Export to Autodesk Map Guide.
> dcolby
> jtby wrote:
>   How do you convert shapefile to SDF?  I hear of SDF loader, but can't
> find
> anything like that, where do I look?
> Thanks,
> JB
> mapguide-users mailing list
View this message in context:
http://www.nabble.com/shapefile-to-SDF-tf3378477s16610.html#a9403839
