[mapguide-users] javaviewersample shows jsp source
Kamil Barbachowski kamil.barbachowski at gmail.com
Tue Mar 13 05:23:28 EDT 2007
Hi Farah,
I've done all those steps plus I've started manually Tomcat server-without
this I've recived error 503 - Service Temporary Not Aviable ( I use boundled
Apache, Tomcat and PHP ) and right now I've got following sorce error:
An error occurred at line: 22 in the jsp file:
/javaviewersample/utilityfunctions.jsp
Generated servlet error:
Type mismatch: cannot convert from MgLayerBase to MgLayer
I haven't modified source code of sample java applicatio.
Somebody have any idea what could be wrong.
I will try to run MapGuide Studio as sugested Dhirendra Kumar
Best regards
Kamil
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Farah
Sent: Tuesday, March 13, 2007 6:06 AM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] javaviewersample shows jsp source
Hi Kamil,
These are the things you need to do:
1)       Copy the sheboygan .mgp file to the Packages folder.Load the
sheboygan data  using the site admin.
2)       Copy the javaviewersample code into your www folder.
3)       Add the following line to your Apache httpd.conf file:  JkMount
/mapguide/javaviewersample/* worker1
4)       Restart your ApacheMapguide Service
5)       Try running your sample again.
farah
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kamil
Barbachowski
Sent: Thursday, March 08, 2007 4:40 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] javaviewersample shows jsp source
Hi!
I got a problem getting started with mapguide.
I've tried to run the sample application for jsp, but
<http://localhost:8008/mapguide/javaviewersample/ajaxtiledviewersample.jsp>
gives just jsp source code instead of processing.
Can somebody help me with that?
best regards,
Kamil
Disclaimer by Mail Administrator - Yukthi
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070313/375df14d/attachment.html
