[mapguide-users] Creating a New Feature Join between (FeatureSourceand database-table)
Dave Wilson dave.wilson at autodesk.com
Wed Mar 14 10:47:41 EDT 2007
You appear to have the join backwards. Always make the join from your
main geometry based source you wish to display. Open CenterLines and
join to your postgreSQL table. The ID fields need to be of the same
datatype.
When you create the layer select the new featureclass created in the
join. DO NOT SELECT the new geometry.
Regards,
Dave
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Maciej
Skorczewski
Sent: Wednesday, March 14, 2007 5:02 AM
To: MapGuide Users Mail List
Subject: [mapguide-users] Creating a New Feature Join between
hi all!
i have problem whit create New Feature Join - can't see label from
database.
I try make New Feature Join between:
+ postgreSQL table  (id,name,id_street)
+ Library://Samples/Sheboygan/Data/RoadCenterLines.FeatureSource
(ID,NAME)
i try create join whit ID=id_street , so i can get new street "name"
from database .
i make this:
1. I create new Data Connection (i chose OGR provider) -it work corect i
use it whit PostGIS data to get shape from database.
2. ...put connection string ...test it ->Successful connection.
3. I open tab (Join whit other feature source)....
...first get table name from database
http://img218.imageshack.us/img218/6338/29497353xr8.jpg
...second Feature source (this is source of Roads label in Sheboygan
example)
http://img219.imageshack.us/img219/3623/22607262bi4.jpg
4. i create label whit source of data connection
http://img218.imageshack.us/img218/70/25959333jd0.jpg
after that i can't see anything. any label...studio can get value of
this data (when i create test  expresion) ...but still can't see on map.
http://img207.imageshack.us/img207/1710/80628499mn1.jpg
can anybody help me? what is wrong?
maciek.
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
