[mapguide-users] Show/Hide Layers and propertiespane programmatically
Maciej Skorczewski maciej.skorczewski at procad.pl
Mon Mar 19 08:11:32 EDT 2007
hi Willem !
i still don't have time for that...all time spend on develop new
mapguide aplication.
But try my preview post i send source code of may solution.. maybe you
can find solution...
i try make this but in some 4-5 day.
all you should to do is
a) look inside html code (try http://www.getfirebug.com it help) - i
call frame by id so you must add ID in some  playce, then call this by
javascript function...i make this to right tast pane...i thing that can
make to left pane too.
maciek
Willem Schwarte napisał(a):
> Hi Maciek,
> Did you happen to solve this problem of hiding/showing the legend pane?
> Willem
