[mapguide-users] RE: RE: MGOS Application Overlaying on GOOGLE
Dhirendra Kumar dhirendra.mgos at gmail.com
Wed Mar 28 02:35:36 EDT 2007
Hi Andy Morsell,
Thankyou for your replay, Now i can see my map on google earth with their
right position. Is it possible to view this map directly on google map
website ? because, if client's  computers has not installed Google earth
then they can't see this feature. So for that resion i am asking to you
MapGuide integration with Google map website. Help me I am waiting
Thankyou in Advance
Dhirendra Kumar
Andy Morsell wrote:
> You can build a web interface that has hyperlinks, or buttons, or whatever
> that the users interact with.  Behind the scenes, you are sending them to
> the full mapagent URL's.
> Andy
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dhirendra
> Kumar
> Sent: Saturday, March 24, 2007 4:39 AM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] RE: MGOS Application Overlaying on GOOGLE
> Hi Andy Morsell,
> Thankyou for your valuable replay, according to you, first i uninstalled
> MapGuide 1.0.2 and install 1.1.0 and as per your suggestion open file
> http://com008:8008/mapguide/MapAgent/index.html/ and  click on KML option
> and GetMapKml and fillup all information, when i click on subbmit button
> then my maps automatically overlap on Google earth with their right
> projection ( So i am verry happy to see this). But my problem is, when i
> want to see my maps on google earth then every time i have to open
> mapagent
> and manually click on Subbmit button. But my client want to click on one
> link (not manually) and google earth display map automatically. So for
> that
> resion i want  to know mapagent  generate .KML file in which place and by
> default which name (i want to give name manuall then what i have to do).
> So
> please suggest me. i am waiting
> ........................................................, thankyou once
> again for your valuable information.
> Thanking you
> Dhirendra Kumar
> Andy Morsell wrote:
>> MapGuide Open Source 1.1.0 has the capability "out of the box".  There
>> is no documentation, but it's pretty straight-forward to utilize by
>> issuing operation requests directly against the mapagent.  To try it
>> out, load up the mapagent test page
>> (http://YOURSERVERNAME:PORT/mapguide/MapAgent/index.html).  Then, in
>> the upper-left pane click on Kml.  Then, go to the GetMapKml,
>> GetLayerKml, or GetFeaturesKml options.  Here's the results of issuing
>> the default operations from that interface:
>> http://YOURSERVERNAME:PORT/mapguide/mapagent/mapagent.fcgi?OPERATION=G
>> ETMAPK
>> ML&VERSION=1.0.0&FORMAT=KML&DPI=96&MAPDEFINITION=Library%3A%2F%2FSampl
>> es%2FS heboygan%2FMaps%2FSheboygan.MapDefinition
>> ETLAYE
>> RKML&VERSION=1.0.0&FORMAT=KML&DPI=96&DRAWORDER=0&LAYERDEFINITION=Libra
>> ry%3A%
>> 2F%2FSamples%2FSheboygan%2FLayers%2FParcels.LayerDefinition&BBOX=-87.7
>> 398334
>> 220901%2C43.73822699224595%2C-87.72068284176505%2C43.75068777906662&WI
>> DTH=79
>> 6&HEIGHT=717
>> ETFEAT
>> URESKML&VERSION=1.0.0&FORMAT=KML&DPI=96&DRAWORDER=0&LAYERDEFINITION=Li
>> brary%
>> 3A%2F%2FSamples%2FSheboygan%2FLayers%2FParcels.LayerDefinition&BBOX=-8
>> 7.7398
>> 334220901%2C43.73822699224595%2C-87.72068284176505%2C43.75068777906662
>> &WIDTH
>> =796&HEIGHT=717
>> There's also ways to do cool KML things via the MGOS and FDO API's,
>> but these are obiously more advanced.  For an example, see these pages:
>> http://earth.nanaimo.ca/
>> http://www.spatialgis.com/demo.html
>> http://mapguide.osgeo.org/livegallery.html
>> Andy Morsell, P.E.
>> Spatial Integrators, Inc.
>> http://www.SpatialGIS.com
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Paul
>> Spencer
>> Sent: Friday, March 23, 2007 6:12 AM
>> To: MapGuide Users Mail List
>> Subject: Re: [mapguide-users] MGOS Application Overlaying on GOOGLE
>> Unfortunately I don't know anything about this.  Perhaps someone else
>> will jump in here?
>> Paul
>> On 23-Mar-07, at 2:29 AM, Dhirendra Kumar wrote:
>>> Hi Paul,
>>> Thank you for replay, But i have no idea how to use MapGuide as a KML
>>> server. If you have any information then please give me.
>>> Thankyou in advance
>>> Dhirendra kumar
>>> Paul Spencer-5 wrote:
>>>> Dhirendra,
>>>> This is probably a difficult thing to do ... I think you can use
>>>> MapGuide as a KML server for Google Earth.  I'm not sure if Google
>>>> Maps can load KML directly yet.
>>>> You can also look at using OpenLayers (http://www.openlayers.org) to
>>>> build your web client since it can use Google Maps API to load
>>>> Google maps and then overlay other layers (using WMS for instance).
>>>> You could probably launch an OpenLayers app from MapGuide, but
>>>> again, it's not going to be trivial to set up.
>>>> Cheers
>>>> Paul
>>>> On 22-Mar-07, at 8:06 AM, Dhirendra Kumar wrote:
>>>>> Hi All,
>>>>> I devloped GIS Election Application using MGOS and now i want to
>>>>> overlaying my application on Google. Requirment is when user will
>>>>> click on link of right pane of Ajaxviewer then map's are displaying
>>>>> in central window get overlapped on GOOGLE with their right
>>>>> Position and preserve shape.
>>>>> But i
>>>>> have no idea about this, So Any Boady Please help me. I am
>>>>> waiting...........................................................
>>>>> Thankyou in advance
>>>>> Dhirendra Kumar
>>>>> View this message in context: http://www.nabble.com/MGOS-
>>>>> Application-Overlaying-on-GOOGLE-tf3446638s16610.html#a9611820
>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>> _______________________________________________
>>>>> mapguide-users mailing list
>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>> |Paul Spencer                          pspencer at dmsolutions.ca    |
>>>> |Chief Technology Officer                                         |
>>>> |DM Solutions Group Inc                http://www.dmsolutions.ca/ |
>>> Application-Overlaying-on-GOOGLE-tf3446638s16610.html#a9629094
> http://www.nabble.com/MGOS-Application-Overlaying-on-GOOGLE-tf3446638s16610.
> html#a9649073
View this message in context: http://www.nabble.com/MGOS-Application-Overlaying-on-GOOGLE-tf3446638s16610.html#a9707139
