[mapguide-users] Suitable Database for MapGuide using FDO
George McLean gmclean at gorge.net
Thu Mar 29 09:49:22 EDT 2007
I have been using MySQL to store spatial features and it seems to work
well. I did find one problem in the FDO provider that came with MGOS.
When reading multiple records in a feature reader, string fields would
not clear from the previous record. This meant that if the first record
had a string field with the data 'abcdef' and the next record had the
string 'xyz' in the same field, the provider would return 'xyzdef' for
the second record. This has been fixed in the FDO provider code but you
will have to recompile the provider yourself, at least that is what I
had to do to get it to work.
George McLean
Dhirendra Kumar wrote:
> Hi All,
> I am devleoping Election GIS System using MapGuide and my client requirment
> is to update data during run time. Example :- Suppose today we have 30
> booths in one district and next year it would increase by 10. then how will
> i display on layer, right now i have only one solution of this problem is
> that create new SHP file and place in MapGuide manually. But my client
> requirment is updation should be Run time automatically. Is it possible
> using FDO ? if yes then which database will be suitable for MapGuide ? and
> please give me detail how will i use FDO in MapGuide. Please help me. I am
> waiting.....................................................
> Thankyou in Advance
> Dhirendra Kumar
