[mapguide-users] RE: Feature Joins Failing in MapGuide Open
James Card James.Card at calcad.com
Tue May 1 18:40:57 EDT 2007
On Tue, 01 May 2007 11:50:06 -0700, Ronnie Louie
<ronnie.louie at autodesk.com> wrote:
> I have seen a similar problem where the newly created joined feature
> class does not appear in the when creating a layer.  The problem is
> related to the feature class not updating correctly.  If you user Server
> Admin to toggle the Online/Offline status of the server, it will force
> the cache to update.  After doing this, I am able to see the new feature
> class when defining a layer.
Thanks, that does seem to resolve that issue, but now there is another
one. When trying to theme the layer on any of the fields from the joined
table we get this message:
   Unable to complete request to Site
   An exception occurred in FDO component.
   String does not represent a valid expression.
The feature join seems to work fine other than the theming problem.
James Card
California CAD Solutions, Inc.
209 578-5580
