[mapguide-users] MySQL connection error - unsupported buffer type?
Ryan Miller ryan.miller at kirtland.af.mil
Wed May 2 10:00:54 EDT 2007
Did you get this resolved?  I'm getting the same error message when trying to
connect to mysql.
Ryan
kgrootendorst wrote:
> Hello,
> Using MGOS 1.1, FDO 3.2, MySQL 5.0.22, Win2000...
> I have success with setting up a MySQL connection for an application on my
> local drive.
> Now that I have 'moved' the application to a remote server, I am running
> into a mysql connection error.  I can't seem to find anyone with a similar
> problem, nor have I been able to resolve the error with any success. Below
> is a dump from the server log.  Does anybody have any ideas?
> Error: An exception occurred in FDO component.
>         RDBMS: Using unsupported buffer type: 0  (parameter: 1)
>  StackTrace:
>   - MgFeatureServiceHandler.ProcessOperation line 83 file
> c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
>   - MgOpTestFeatureSourceConnection.Execute line 103 file
> c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\server\src\services\feature\OpTestFeatureSourceConnection.cpp
>   - MgFdoConnectionManager.Open line 815 file
> c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\server\src\common\manager\FdoConnectionManager.cpp
> Thanks in advance.
> Kevin
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/MySQL-connection-error---unsupported-buffer-type--tf3675443s16610.html#a10286500
