[mapguide-users] carto_neotic@yahoo.fr
Stefan Dalakov s.dalakov at mapware.net
Fri May 4 07:03:29 EDT 2007
1. You are posting on a wrong place - this is for MapGuide OpenSource.
It seems that you are using Mapguide 6.x.
2. Coordinates of points coming from OLE DB Data source are assumed to
be in decimal degrees - there is no other option - you should have
Lat/Lon values in your database. However your map can be in any
projection and coordinates are transformed (reprojected) on the fly
Stefan.
Ariane BARNA wrote:
> Hi,
> I would need information and examples of layers of points built
> through an OLE DB Data Source. In my DataBase, the points should
> follow the Lambert II Etendu map projection system.
> However MapGuide doesn't take the map projection into account and show
> the points using decimal degrees.
> When I create my layer, I cannot define any map projection system for
> the points I give to MapGuide ! I would have thought MapGuide would
> then take for granted that the given coordinates follow the same
> system than the one you precise for the output map.
> And it turns out that MapGuide traduces the points as decimal degrees.
> Is there anyway to fill in the source map projection system ? Or is
> this an already known bug of  Mapguide ?
> Thank you very much for any piece of help.
> Découvrez une nouvelle façon d'obtenir des réponses à toutes vos
> questions ! Profitez des connaissances, des opinions et des
> expériences des internautes sur Yahoo! Questions/Réponses
> <http://fr.rd.yahoo.com/evt=42054/*http://fr.answers.yahoo.com>.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070504/79ba0d2e/attachment-0001.html
